April 14 Evolution ... Earth-Sun Scaling tutorial & Images
Moderator: marktownley
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
A serious evolution between today and yesterday, with a beautiful "arch" forming on this prominence.
ASI 174MM camera with interference eliminator.
Quark Chromosphere
TOA 150-B with Baader DERF.
Quark Chromosphere
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: April 14 Evolution ...
Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
superbe, bravooooooo !!!!
sorry for my English translators google
- MAURITS
Raf, without de eliminator I have NR's with the 174MM.krakatoa1883 wrote: ↑Wed Apr 14, 2021 3:00 pm Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
- Has thanked: 9144 times
- Been thanked: 6025 times
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Great Prom detail Maurits, thanks for sharing your images.
Martin
Martin
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely images Maurits. Thanks for sharing
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17667 times
- Been thanked: 8787 times
Wow!! this is a gorgeous shot
That is one thing I should learn, how to get an Earth on a picture. The biggest downfall for me is that I have never found a decent Earth picture to use and how you get it so small without it being one big pixel?
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Alexandra,
I think this Earth may be reasonably easy to use. I already isolated the Earth, its 673 pixels. I could explain it to you, but I have plans to make a Solar SSM ! I could publish it another time on the tutorials section.
There is some information on Brierley Hill solar blog, although I found the sound very hard to hear and understand.
https://brierleyhillsolar.blogspot.com/ ... rials.html
I had to learn Photoshop, layers and everything. Still not learned it al! after more than 2 years ! You can also use GIMP or Affinity Photo, which are less expensive alternatives and quite adequate.
I only found it after an extensive search online.
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Radon86
Maybe this is easier to see/use.
- MAURITS
Alexandra, I have the "TIF image" that I use in my images as above.
You can use them, can I set it up here as a TIF file?
Thanks a million TIFs aren't displayed in the forum but you can right click and open them
- MAURITS
- Radon86
Alexandra,
Maybe this is better for you. It has the UK near the centre...
- Radon86
Hi all,
I think I have found an easier way to calculate the size of the earth (in pixels) - this will be an option in your imaging program - to resize the earth image. Assuming the diameter of the earth is 109 times smaller than the sun, and the sun is about 30 minutes of arc = 1800 arc seconds.
Then just calculate your image scale using the calculator in:
astronomy.tools
(make adjustments for your optical train) - once you have this reasonably accurately: then (image scale is in arcseconds/pixel).
size of earth (pixels)= 16.514/(image scale)
This will save you the hassle of having to draw a large circle in photoshop, measure the diameter of the sun in millimetres and dividing it by 109 to get the diameter of the earth.
I am sure this has been done before, but not able to find a reference to it.
If I am wrong, then please correct my error(s).
Hope this helps.
Magnus
astronomy.tools
Hope this helps.
Magnus
- Been thanked: 4900 times
Two excellent images Maurits of the prom showing fine detail
Thanks for sharing
Regards
Thanks for sharing
Regards
- Has thanked: 173 times
- Been thanked: 615 times
Here's an Aussie version.....
