Colorize inverted image issue
Jordan Konisky
Has thanked: 100 times
Been thanked: 77 times
Post by Jordan Konisky »
Image15_25_47Z_l4_ap2195imppg1.75invcolor by Jordan Konisky, on Flickr
When I invert an image via imppg and then colorize in photoshop, the background remains white (see attached). How do I convert this background to black? Thanks for suggestions and help.
Jordan
Has thanked: 7068 times
Been thanked: 3356 times
Re: Colorize inverted image issue
Unfortunately if you invert black, it becomes white ;)
You would need to select that portion of the image with a mask and only invert the disc space. I can't imagine it would look nice. This is one reason I am never a fan of inverted images. I don't like white sunspots, they just look wrong to me. I did once colourise an inverted image so that it had a blue background. I would love to remember how I did that :? even better, where is that picture?
nicspenceryork
Has thanked: 663 times
Been thanked: 101 times
Post by nicspenceryork »
I’m with Alexandra in finding inverted white sun spots less easy on the eye! I do however like an inverted spotless disc edge/limb with a white prom and darker sky and there’s a ‘double inversion’ technique in Simon’s video which was a game changer for me.
Watch this about 32 minutes in:
https://www.youtube.com/watch?v=-zD4EIGBess
Good luck with it
That's a video gem, thanks Nic. I never knew you could twist the histogram on its head like that. You learn something new every day!!
Ivan
Has thanked: 1925 times
Been thanked: 1020 times
Post by Ivan »
Jordan Konisky wrote: Fri Sep 24, 2021 4:56 pm
Jordan
If I need a dark background on inverted photos, I use roughly the same curve settings in ImPPG. The light spots look a little odd though.
Ivan
Has thanked: 121 times
Been thanked: 370 times
Alexandrs,
The blue background etc usually happens when you invert only one colour of an RGB image.
Has thanked: 6334 times
Been thanked: 5069 times
Post by DeepSolar64 »
In GIMP I use select-by color and then use black to replace the white background with black.
JP
