Solar processing in Pixinsight
Moderator: marktownley
torsinadoc
Has thanked: 749 times
Been thanked: 306 times
Post by torsinadoc »
My normal processing is a combination of ImPPG and PS but decided to work in PI recently. I think my preference is sharpening in ImPPG and then touch up in PI. There are some interesting tools in PI.
Import image then crop out borders
Screen Shot 2021-12-24 at 9.29.21 AM.jpeg (78.6 KiB) Viewed 627 times
Run DBE only selecting background
Screen Shot 2021-12-24 at 9.35.01 AM.jpeg (167.91 KiB) Viewed 627 times
Sharpen. You can use restoration filter (easier) OR deconvolution. both you need to guess PSF size and then unsharp mask. you can also sharpen with wavelets
Screen Shot 2021-12-24 at 9.37.07 AM.jpeg (89.39 KiB) Viewed 627 times
Screen Shot 2021-12-24 at 9.39.31 AM.jpeg (100.93 KiB) Viewed 627 times
Comparison between RF and Decon
Screen Shot 2021-12-24 at 9.40.19 AM.jpeg (61.31 KiB) Viewed 627 times
Unsharp Mask after deconvolution
Screen Shot 2021-12-24 at 9.43.08 AM.jpeg (75.32 KiB) Viewed 627 times
Boost contrast with LHE. I will use large and a small kernel size (512 and 16) with small amount
Screen Shot 2021-12-24 at 9.45.42 AM.jpeg (245.02 KiB) Viewed 627 times
Screen Shot 2021-12-24 at 9.46.06 AM.jpeg (255.15 KiB) Viewed 627 times
Then blend in with pre LHE to soften it a little.
Here are a couple of pixelmath options (I tend to adjust the amounts blended).
Screen Shot 2021-12-24 at 9.46.47 AM.jpeg (248.91 KiB) Viewed 627 times
or
Screen Shot 2021-12-24 at 9.46.57 AM.jpeg (242.5 KiB) Viewed 627 times
I used (a * .2) + (b *8)
Then touch up with curves and HST
Image12-12-21 Ha by Diamond, Alan, on Flickr
torsinadoc
Re: Processing in Pixinsight
Here is how I generate a pseudoflat
duplicate image and remove structures
Screen Shot 2021-12-24 at 10.21.55 AM.jpeg (79.85 KiB) Viewed 624 times
DBE (just generate background model without correction)
Screen Shot 2021-12-24 at 10.22.11 AM.jpeg (93.69 KiB) Viewed 624 times
Need to resample the DBE background model
Screen Shot 2021-12-24 at 10.22.50 AM.jpeg (50.82 KiB) Viewed 624 times
Use pixelmath resampled background model from original (adjust the equation for desired effect)
Screen Shot 2021-12-24 at 10.24.41 AM.jpeg (160.11 KiB) Viewed 624 times
Here are a couple of masks that can be used to focus on pertain areas of the image. I blur with convolution to generate a softer mask
Screen Shot 2021-12-24 at 10.27.11 AM.jpeg (62.1 KiB) Viewed 624 times
Screen Shot 2021-12-24 at 10.26.29 AM.jpeg (73.09 KiB) Viewed 624 times
Rob63
Has thanked: 64 times
Been thanked: 55 times
Post by Rob63 »
Excellent tutorial, I have been playing with Pi for my solar images but have never really settled on a workflow so this is a big help.
torsinadoc
Rob63 wrote: Fri Dec 24, 2021 4:48 pm Excellent tutorial, I have been playing with Pi for my solar images but have never really settled on a workflow so this is a big help.
You can extract wavelets to find where the noise and structure reside then use wavelets to sharpen and do noise reduction (on original not the extracted layers). Extracted layer 0 corresponds with layer 1 in ATVW and layer 1 corresponds to layer 2 in ATVW, etc
Screen Shot 2021-12-24 at 11.02.49 AM.jpg (93.2 KiB) Viewed 606 times
Screen Shot 2021-12-24 at 11.04.50 AM.jpg (226.26 KiB) Viewed 606 times
Screen Shot 2021-12-24 at 11.05.29 AM.jpg (87.54 KiB) Viewed 606 times
rsfoto
Has thanked: 3706 times
Been thanked: 2532 times
Post by rsfoto »
Hi and WOW
:shock: :shock: :shock:
Boso36
Has thanked: 244 times
Been thanked: 201 times
Post by Boso36 »
Thanks Rob,
Still only learning the basics. Too advanced for me.
Magnus.
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
torsinadoc
Boso36 wrote: Fri Dec 24, 2021 6:32 pm Thanks Rob,
Magnus.
I previously only processed in PI then transitioned to PS about 3 years ago. I wanted to revisit the older techniques and add in a few more. I still like sharpening and curves (to bump up proms) in ImPPG but can use PI for techniques when warranted.
torsinadoc
Re: Solar processing in Pixinsight
How to annotate an image
Screen Shot 2021-12-25 at 5.06.54 AM.png (402.69 KiB) Viewed 556 times
Boso36
Post by Boso36 »
Yes, I have seen Pixinsight processing on Youtube e.g. Chuck's astrophotography. Seems really easy when you know how.
I am sure it is not impossible, just that I thought Pixinsight is more for deep sky imaging processing e.g. Eagle Nebula, Tarantula nebula, Andromeda M31 etc
Magnus
torsinadoc
Boso36 wrote: Sat Dec 25, 2021 11:12 am Yes, I have seen Pixinsight processing on Youtube e.g. Chuck's astrophotography. Seems really easy when you know how.
Magnus
It is definitely designed for deep sky but can be adapted for lunary, solar.
Boso36
Post by Boso36 »
Fascinating. I was wondering if you could envisage a way of automating solar image processing in Pixinsight, like AI to retouch a face in seconds ? It would take 4-6 hours for a human to do this.
Just wondering.
Magnus
torsinadoc
Yes, you use processcontainer and drag to the image or image container for several images
For example
I processed a Cak image
Open history explorer in the side bar
Screen Shot 2021-12-25 at 6.12.53 AM.png (725.91 KiB) Viewed 538 times
Open processcontainer and drag from history explorer to processcontainer
Screen Shot 2021-12-25 at 6.13.47 AM.png (294.12 KiB) Viewed 537 times
Then drag the new instance ( triangle ) in the left lower corner to the workspace and save process (process-> process icons-> save process icons) and it will be saved for future images. You can open and drag to an image and it will process it quickly
Screen Shot 2021-12-25 at 6.15.02 AM.png (465.61 KiB) Viewed 538 times
It works great for animations combined with image container
I process a single image then drag the history to processcontainer and then load all the other images in imagecontainer (you have to drag the "new instance" (triangle) in imagecontainer to the workspace) then apply processcontainer and it will apply to every image in imagecontainer.
Screen Shot 2021-12-25 at 6.15.28 AM.png (173.71 KiB) Viewed 538 times
Screen Shot 2021-12-25 at 6.13.47 AM.png (294.12 KiB) Viewed 538 times
Boso36
Post by Boso36 »
Thanks Torsinadoc,
Very powerful.
This should be referenced in Software Processing section of this forum, I wish I could bookmark this page for future reference.
Thank you so much.
Magnus
torsinadoc
You can also drag processes that you normally use in your workflow to processcontainer and save to workspace then open an image and processcontainer and double click each process and adjust to your liking.
Has thanked: 7106 times
Been thanked: 3367 times
Thanks Alan, once all the additions have calmed down I will put a copy in the library so everyone can find it more easily :)
torsinadoc
If you don't want to use pixel math, you can use "blend" script. This functions like layers in PS
Screen Shot 2021-12-26 at 11.21.35 AM.png (155.06 KiB) Viewed 481 times
AJamesB
Has thanked: 734 times
Been thanked: 388 times
Post by AJamesB »
Great write up! I've found that for most instances, I prefer pixensight and deconvolution for my solar sharpening, especially when using the combined wavelet noise reduction, and then doing multiple iterations at progressively finer levels of detail. It seems to let me get a bit finer detail but with much less noise/artifacting than I'm able to get via imppg.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
MoonPrince
Has thanked: 6 times
Been thanked: 132 times
Post by MoonPrince »
That's a great tutorial, I will try your processing method later :D
Thanks for sharing!
Telescope: ES127 CF APO, Skywatcher 80mmF5 Ha scope
Mount: SW AZEQ6, iOption GEM45.
Camera: Player One Apollo-M MAX(IMX432), Apollo-M(IMX174), Apollo-M MINI(IMX429)
Accessories: Daystar Quark Chromosphere, Herschel prism, TV5X, TV2.5X
Has thanked: 3534 times
Been thanked: 3185 times
Thanks for this. There’s some really great information here. I use a combination of ImPPG and PixInsight, but haven’t really explored PI deeply enough to understand all possible processing options, so information such as this is extremely helpful, especially applying FD false flats. I also haven’t explored using process container and start from fresh each session, which can be tedious when setting up various parameters.
This is yet another excellent example of the benefit to all of this generous knowledge sharing forum.
Thank you.
Has thanked: 6843 times
Been thanked: 3171 times
Excellent resource, thanks!
Any further thoughts anyone?
torsinadoc
Here is an excellent reference for PS blending using pixelmath
http://trappedphotons.com/files/Present ... ations.pdf
And I have no further thoughts
