Reflection
- Has thanked: 60 times
- Been thanked: 78 times
Reflection
Right, I have now got rid of most of the reflections in my Lunt 50. But I am still left with this big one! Is this coming from the first ERF (red filter)? Will tilting it even more get rid of it? I assume tilting it too much would be bad as well?
Thanks!
Thanks!
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
- Been thanked: 8906 times
Re: Reflection
Yes they do! This post might be better off in the mod section?
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- Has thanked: 20819 times
- Been thanked: 10489 times
Re: Reflection
Try tilting the ERF and see what happens.
Does it move when you rotate the blocking filter?
Re: Reflection
I will give it a go next time im out
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Re: Reflection
Well it is not the ERF! It's somewhere in the blocking filter. Weird
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- rsfoto
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: Reflection
Is that the full frame ?Gingerfish wrote: ↑Sun Apr 24, 2022 1:15 pm Right, I have now got rid of most of the reflections in my Lunt 50. But I am still left with this big one! Is this coming from the first ERF (red filter)? Will tilting it even more get rid of it? I assume tilting it too much would be bad as well?
Thanks!
Re: Reflection
Try reseating the ITF element in the blocker.Gingerfish wrote: ↑Tue Apr 26, 2022 4:24 pm Well it is not the ERF! It's somewhere in the blocking filter. Weird
Have you got another blocker you can try (or borrow to try?)
Re: Reflection
No, not full frame. Taken with my QHY183M (1" sensor). I usually use my ASI178mm, but it died the other night
No, I don't have another BF. But I will try reseating it.
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- rsfoto
Re: Reflection
Hi,Gingerfish wrote: ↑Tue Apr 26, 2022 11:29 pm No, not full frame. Taken with my QHY183M (1" sensor). I usually use my ASI178mm, but it died the other night
Center exactly the Sun and see if the Ghost is still there.
Re: Reflection
Yes, it is there with the 178 as well, and it is centered in the middle.
I did not make it home in time to try today. Hopefully I will be able to run a quick test tomorrow
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Re: Reflection
Reseating it seems to have done the trick! No idea how it has worked itself loose in the first place, but oh well
Thank you!
Thank you!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- rsfoto
Re: Reflection
Hi Mark,marktownley wrote: ↑Tue Apr 26, 2022 5:22 pmTry reseating the ITF element in the blocker.Gingerfish wrote: ↑Tue Apr 26, 2022 4:24 pm Well it is not the ERF! It's somewhere in the blocking filter. Weird
What did you mean with reseating ?
Re: Reflection
Tale out the ITF, wiggle it, put it back in at a slightly different angle than it was beforersfoto wrote: ↑Thu Apr 28, 2022 5:12 pmHi Mark,marktownley wrote: ↑Tue Apr 26, 2022 5:22 pmTry reseating the ITF element in the blocker.Gingerfish wrote: ↑Tue Apr 26, 2022 4:24 pm Well it is not the ERF! It's somewhere in the blocking filter. Weird
