Your recommendation for an eyepice for public solar viewing?
- danpro1
- Has thanked: 21 times
- Been thanked: 29 times
Hello everyone,
Hope that you are all doing well.
I have recently acquired a very portable solar H alpha kit (Lunt 60mm DS/Takahashi Teegul-SP/carbon fiber tripod) to do public viewing. It was very popular during an Astrofest in Montreal yesterday! I was wondering if people have had the chance to compare eyepieces for use such as for solar viewing for the public? The ease of eye alignment with the eypiece (eye relief, among other factors ?) is very important for people who have not looked into an eyepiece before, and the intensity of the daylight closes the eye iris, so the challenge is different than, say, at night. My goal is to maximize public fun while looking at the Sun through this setup. Focal length of the eyepiece is around 8-10mm for proper magnification in this case. I also make sure that the head of the viewer is in shadow to minimize glare.
Thank you for your recommendations,
Daniel
Daniel
- Has thanked: 17572 times
- Been thanked: 16693 times
Re: Your recommendation for an eyepice for public solar viewing?
For my 60mm Coronado I would use my Coronado Cemax 25mm and Orion 16mm EF eyepieces giving 16x and 25x respectively for low power high contrast views. I will sometimes use a Lunt 19mm eyepiece ( 21.5x ) and Coronado Cemax 12mm ( 33x ) as well. Only during good seeing and with bright features will I go higher, especially in single stack. I do have a Lunt 8mm which I occasionally use for 50x views.
The SolarMax II 90 is a different animal and will do much better at higher magnifications. Commonly double what the 60 will do.
- Has thanked: 20424 times
- Been thanked: 10243 times
I would go for a Baader hyperion.
- Been thanked: 4900 times
EXACTLY AS MARK HAS JUST SAID.
THE HYPERION CLICK-STOP ZOOM 8 - 24 MM EP'S ARE IDEAL FOR PUBLIC OUUTREACH EVENTS AS FAR LESS MESSING-AROUND SWAPPING EP'S AND ESPECIALLY FOR THE 60MM LUNT+DS SCOPES...
ALSO ANY 8-24MM ZOOM EP'S TOO..
CLEAR SKIES
TERRY
CLEAR SKIES
TERRY
I agree. I need a good zoom eyepiece.
- Has thanked: 1640 times
- Been thanked: 878 times
I second the Baader 8-24 zoom. I used it with my Lunt 60 this weekend for solar outreach. It’s a nice match
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Another +1 for the Hyperion Zoom here. The flexibility of a good zoom is hard to beat for these type of situations.
Its eye relief is fairly decent, so I wouldn't worry too much about that (apart from the bright daylight hitting the other eye/face; which is always gonna be a thing of course). The only downside is that (like pretty much all zooms), it's not parfocal; so you'll find yourself having to slightly refocus if someone wants to increase/decrease the used EP focal length. If that's not something you want to have to deal with, I would just go for a plossl at whatever focal length you find appropriate (16-20'ish or so) and leave it at that.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Daniel,
I'm using eyepieces, " telescope's focal ratio X2 (frX2)." If I used 40mm f10 the best eyepiece F.L.20mm and e.t.c.
I have the Celestron zoom 8-24 /40°-60° and is not bad at all! The low power always is better...my opinion
Marios S.Ioannou
Sketcher/Visual Observer
- danpro1
Thank you all for your recommendations; they are appreciated!
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
I have been looking at a couple of zooms from Orion as well as the Lunt zoom. Eye relief matters.
