AR13007 closeup with Apollo Max cam, 11.05.2022
- Has thanked: 2977 times
- Been thanked: 2082 times
today seeing was ok but compromized by jet stream speeds. But i could play around with the newly arrived apollo max cam and here is a first result of it. Still optimizing since its a quite different optical train.
Its recorded in 12 bit and around 330 stacked images (10% of 3300, 30 sek). For such a s/n result i usually stack around 960 frames (20% of 4800, 30 sek) with the asi 174mm.
The dynamic range manifests also in the editing process so i still have to figure out how to dampen the bright parts and i know its overall a bit too dark.
more coming soon.
Dennis
(160mm d-erf, 1500/1200 SW AC, t2 bbhs mirror diagonal, TV 2x Big Barlow, Quark, Apollo Max)
more coming soon.
Dennis
- 0713_0_.png (1.01 MiB) Viewed 663 times
- 0632_7_.png (897.19 KiB) Viewed 663 times
- 0730_0_.png (842.11 KiB) Viewed 663 times
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Re: AR13007 closeup with Apollo Max cam, 11.05.2022
Beautiful images, Dennis!
What focallength f/number are these obtained at?
Arne
Arne
Thank you Arne,
well.. there is the f/8 scope, the 4.3 quark telecentric and the 2X TV Barlow, so i think its around f/69 if im not mistaken.
Dennis
Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 17666 times
- Been thanked: 8787 times
- Petrus
- Has thanked: 1496 times
- Been thanked: 684 times
Wow! Great results. Very exciting to follow about your test with this camera, thank you for sharing.
~ Petrus ~
Flickr
https://www.flickr.com/people/194757663@N08/
LS80THa DSII - Calcium II K module 12mm - Lunt Herschel wedge 1.25" - Quark Chromosphere - Solarscout Quark - Sol'Ex
Flickr
- Has thanked: 9144 times
- Been thanked: 6025 times
Great stuff Dennis. I am also waiting to try my Apollo for high res.
- Been thanked: 4900 times
- Has thanked: 20424 times
- Been thanked: 10243 times
These came out really well Dennis!
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Superb!
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
SW Evostar 72ED for full disk imaging
Sol'Ex SHG
80mm f/7 achromat used with pressure tune module off the Lunt with Lunt 100mm ERF
Bresser 90 f/10 achromat used for CaK & white light imaging & PST mod with Lunt 100mm ERF
Coronado SM40 (pre Meade) and BF10 filter set + SMII 60 richview DS etalon
Skywatcher EQ6 Pro and Ioptron CEM60
Then there is all the night kit which is far too long a list to write up here!
More images on view on my Flickr page...https://www.flickr.com/photos/alun_h/
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17572 times
- Been thanked: 16691 times
Nice images. The spicule layer at the limb shows up very well over the double limb of the photosphere.
Thank you all for your kind words,
a super fun hobby it is : )
best regards
Dennis
best regards
Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
the experimenting continues..
now instead of 10% best images only 5% (164 images).
I still see no noise coming up during processing, this is a great camera.
- 0632_7_.png (1021.51 KiB) Viewed 549 times
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice work, Dennis. Great images on the Apollo.
- pedro
- Has thanked: 14 times
- Been thanked: 6575 times
Great images Dennis, well done
Pedro Re'
