Sol 21-5-22 Ha
- Ibbo
- Has thanked: 2438 times
- Been thanked: 1650 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: Sol 21-5-22 Ha
Much as I saw the Sun today. The solar limb ring looks really nice!!
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: Sol 21-5-22 Ha
Very nice!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: Sol 21-5-22 Ha
A great result Steve, sunshine was in short supply for me yesterday.
- The Sun?
- Has thanked: 2 times
- Been thanked: 21 times
Re: Sol 21-5-22 Ha
Late or not. These are brilliant!
How did you process your final image, the one with a black mask?
I would like to do this with my ha setup and I use the latest PhotoShop update. Some tips/advice would be usefull.
Thank you.
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Re: Sol 21-5-22 Ha
Fantastic images.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
SW Evostar 72ED for full disk imaging
Sol'Ex SHG
80mm f/7 achromat used with pressure tune module off the Lunt with Lunt 100mm ERF
Bresser 90 f/10 achromat used for CaK & white light imaging & PST mod with Lunt 100mm ERF
Coronado SM40 (pre Meade) and BF10 filter set + SMII 60 richview DS etalon
Skywatcher EQ6 Pro and Ioptron CEM60
Then there is all the night kit which is far too long a list to write up here!
More images on view on my Flickr page...https://www.flickr.com/photos/alun_h/
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 1640 times
- Been thanked: 878 times
- Ibbo
- Has thanked: 9145 times
- Been thanked: 6026 times
- Ibbo
Re: Sol 21-5-22 Ha
In Photoshop I click on the disc using the Magic Wand Tool set to Tolerance 50 (this may need tweaking for your images)
then under select -modify- smooth set to 50 (again tweak as needed) - this smooths out the ring.
the using curves I bring down the RHS (255 output to 0)
then deselect and process the ring
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
