Weird behaviour of AS3!
Bastelhannes
Has thanked: 83 times
Been thanked: 138 times
Post by Bastelhannes »
Hi folks,
I get a strange behaviour in Autostakkert3!
Every SER-File i am recording creates a strange red border in AS3. Most of the time the are with image dta is only the right bottom quarter of the screen. The live image is full size nevertheless. It only happens in AS3.
This effect is independent of following parameters:
- change of USB ports: no change
- using different cameras: ASI174MM, ASI178MM, Touptek IMX183MM: same behaviour
- using different USB cable: same behaviour
What made a difference:
- using a different PC: perfect.
The SER-files are correct... SER players show all data.
Does anyone have an idea?
My greatest fear is being married alive.
Petrus
Has thanked: 1727 times
Been thanked: 871 times
Re: Weird behaviour of AS3!
Post by Petrus »
What setting do you have on image stabilization? I get results like this if it is Planet instead of Surface.
Also, I got similar results if tracking was bad (wind, casual knock on the mount...)
~ Petrus ~
Flickr
https://www.flickr.com/people/194757663@N08/
LS80THa DSII - Calcium II K module 12mm - Lunt Herschel wedge 1.25" - Quark Chromosphere - Solarscout Quark - Sol'Ex
Dennis
Has thanked: 3447 times
Been thanked: 2539 times
Post by Dennis »
Looks like you didnt select the "crop" option at the image stabilization options.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Ca-K: homebrew (includes 2x 1.5A filters, thanks Apollo), corrective lenses (thanks again Apollo)
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Bastelhannes
Good hints; I am going to try...
Bastelhannes
SassySun wrote: Wed May 11, 2022 7:50 am What setting do you have on image stabilization? I get results like this if it is Planet instead of Surface.
This is the solution.. I really did this mistake!
Thank you so much!
Petrus
Post by Petrus »
Great! I'm glad I could offer help :)
~ Petrus ~
Flickr
