After three years of procrastinating, I mean planning , the dome went up on the new observatory today.
The past nine months have involved taking down two older observatories and building a new larger one to replace the decommissioned ones. I had a good friend stop by for the afternoon to help with some of the final assembly and installing the dome. Thanks Gord
I will be a week doing up the finishing touches with some paint and caulk, then install the mount and scopes. If I make good time on it I maybe able to image the sun from here on the weekend.
Below are a few of the pics I have of the dome installed adjacent to the large roll off. This makes observatory number five in my life...I hope it is the last, but no promises made to Sandy
I will post a more complete view of it when I have the fine bits finished and the mount/scopes installed.
C14 + Lunt 80ED Deep Sky Work - ASI294MM/Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG Planetary Work - SBIG CFW10, ASI290MM/ASI462+ADC
8' Diameter Dome
MI250 Mount carrying:
Orion EON 130ED, f7 OTA for Day & Night Use Ha Setup: Home Brew Lunt Double Stack/B1800Ha WL & CaK Setup: Lunt WL Wedge or B1800CaK Wedge
Lunt LS80PT/LS75FHa/B1200Ha
Daystar Quantum
ASI1600MM, ASI294MM, ASI174MM, ASI290MM, PGR Grasshopper Express
Excellent, Brian. Glad it all worked out. Looking good there.
Thanks for all of the comments and feedback on the new setup
Rainer, the dome skirt needs to have an extension added before snow flies...the kit needs to be modified to fit onto non-stock walls that NexDome usually sells as a complete set.
8' Diameter Dome
Daystar Quantum
We will see 'smart' it is when it get fully operational
My local conditions should start to improve in the day now that the landscape has green up in the past 2 months, and the crops in the fields now have covered the bare soil so the daytime heating should be reduced.
8' Diameter Dome
Daystar Quantum
