Another good day of weather in London and the SHG was set up for Hydrogen imaging. Rather than try stacking again, which is hard work, I took a huge number of gigabytes of scans and found a few with excellent individual quality. These were full disk images which were cropped to better preserve the resolution and focus on the interesting areas. Clicking on the images will give a better view.
The exposure for H-alpha was 0.8ms, gain 11%, fps 290, scan time 13s. For H-beta, 0.4ms, gain 8%, fps 289, scan time 13s.
The spectral resolution is approximately 0.16 angstrom of H-alpha and 0.25 angstrom for H-beta. The approximate instrument spatial resolution is 3 arcsec.
H-beta, H-alpha, CaH high-resolution SHG images, June 22
- Has thanked: 42 times
- Been thanked: 1487 times
Re: H-beta and H-alpha SHG high resolution images, June 22
I am looking at that with my humble setup. A PST with a Meade electronic EP connected to my TV. What a sight ! It's not anything like that resolution but I see the main things just fine. In fact I set up my camera to make a time lapse vid over hours.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
These are excellent!
I’m a little surprised that you claim a spectral resolution of 0.16 angstroms. How did you measure this?
I also include a CaH image taken shortly after the H-beta and H-alpha images. For this, I again used my 600mm all-camera lens SGH. This one does not yet have as good resolution as my main one based on a 700mm APO triplet telescope. I again attempted stacking to improve noise, this time with 35 individual CaH scans. Some filaments and prominences are visible. But given that the Hydrogen images turned out so well, the lack of sharpness is likely due to optics issues.
I only used Ken's SimSpec SHG v1_3b spreadsheet to calculate the spectral resolution, rather than measuring it.
- Has thanked: 20424 times
- Been thanked: 10243 times
These are very impressive!
I tried a new approach to the stacking process for the CaH image. I used the best 75% of 35 SHG images (which were already hand selected to some degree) in AutoStakkert. I then used Registax 6 wavelets , followed by a little Photoshop. The result was quite good. It's definitely sharper than the first attempt.
The time consuming part is resizing all the individual SHG images to be the same width since AutoStakkert requires the images to all have the same size. The heights of the scans are all the same but the width depends on how many frames are taken. Also, half the images need to be flipped left-to-right since scans are done in both directions. It's probably possible to automate these steps.
