13 July: An assortment of H alpha images.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Everyone.
Here is a selection of some of the regions visible on the very active Sun's surface as of July 13. I've attached a NSO image marked with the active regions I managed to image.
Images were taken with a system comprising: Aries ERF, Celestron C8 Edge, Moonlite CHL focuser, ~4.4x Telecentric, Daystar QPE 0.6A, ~0.7x FR, Point Grey USB3 Grasshopper IMX174. Shots of the ARs were taken at ~ f/44 (~ 8800 mm focal length) as well as ~ f/30 (~ 6000 mm focal length) using the focal reducer. In addition to the on-band H alpha results, I also imaged at 1 angstrom detuned to the blue. Hopefully, all is clear from the figure captions.
Thanks for looking.
Peter
Thanks for looking.
Peter
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: 13 July: An assortment of H alpha images.
These are awesome images, Peter. Very nice indeed.
Very nice images, Peter! Thanks for sharing.
This setup works well. In particular, this Quantum 0.6A.
- Has thanked: 2974 times
- Been thanked: 2082 times
Awesome resolution and images Peter.
I also like the off band ones.. looks like a ellerman party.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 9143 times
- Been thanked: 6024 times
Great views of the sun’s features, Peter. Thank you for sharing them.
- pedro
- Has thanked: 14 times
- Been thanked: 6573 times
Fantastic HR H-alpha imagens Peter, love them all, great resolution
Pedro Re'
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Very impressive set there Peter, thanks for sharing.
Wonderful images, Peter, thanks for showing!
I find the side-by-side comparison of on-band and -1A images extremely instructive and helpful! I am still struggling with the exact tuning of my own h-alpha setup (as you may have noticed from my images from July 11th). On Wednesday I have imaged the very regions you captured, too - I just posted three images here: viewtopic.php?t=37145.
Looking i.e. at the AR13055 images side by side seems to me to confirm that my image is in the blue wing: I can find every one of the conspicuous bright spots around the left-hand sunspot on my image also on your -1A image. On the other hand on your image there seem to be more smaller bright dots. None of the bright spots is to be found on your on-band image. Although the processing of the images is of course different this looks to me like my filter's detuning is a bit less than 1A, but certainly in the blue.
A question, if I may: Would you mind to say what you use for sharpening your high resolution images? They look nice and smooth and not overshapened at all. (Mine probably are mostly oversharpened, but I find it hard to avoid that and still bring out the fine structures. I'm using LR deconvolution and several passes of unsharp mask usually.)
Frank
Frank
- rigel123
- Has thanked: 8309 times
- Been thanked: 8537 times
Excellent set Peter!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- p_zetner
Dear Maurits, Stu, Valery, Dennis, Franco, Pedro, Arne, Mark, Frank and Warren; Thanks very much for your kind comments!
Frank: I'm always wrestling with my tendency to oversharpen but I think I've finally got the hang of applying the right amount. Seeing as I have a single stack, 0.6 angstrom bandpass filter, there is usually quite a lot of detail present in the images, especially in spot penumbrae so I try to bring this out as much as possible. Although I haven't been successful with it yet, double stacking processing would, I think, rely more on contrast enhancement than sharpening. I don't use any deconvolution (regularly, anyway) because I find it tends to introduce artifacts into the image, especially if followed by mild sharpening. I've attached a three-pane image which shows the original stacked image (25/2000) on the left, a wavelet sharpened image (centre) and a "Maximum Entropy" deconvolution followed by mild wavelets on the right. The stacked / unprocessed is already not bad and speaks to the good seeing I had for the July 13 imaging session. I use Astrospheric for seeing forecasts and find it to be pretty reliable.
The deconvolution (right pane) is overdone but it shows the characteristic "wormy" pattern I've come to recognize in a lot of overly deconvolved images. The deconvolution and the wavelet sharpening was done with Astra Image. I really like this version of wavelet sharpening. Size scales are well divided into 5 groups, all useful. It's better than the ImagesPlus multiresolution sharpening in which, generally, only 3 of the 5 size scales are useful. I've used LR deconvolution in ImagesPlus in the past but have only found it marginally worthwhile. Personally, I don't like ImPPG deconvolution / sharpening at all and a lot of images with obvious "worminess" seem to come from using this software. I've also used "Smart sharpen" in Photoshop and unsharp mask in ImageJ. In the end, the Astra Image sharpening process seems to be superior and is my go to choice.
Hope this helps.
All the best.
Peter
Hope this helps.
All the best.
Peter
- KMH
- Has thanked: 641 times
- Been thanked: 725 times
Peter,
Those are terrific images!
I also really like Astra Image for sharpening. For me the LR deconvolution generally provides the most pleasing results, but as you say it is easy to overdo it. "Worminess" is a good description when that happens.
Kevin
Kevin
- Has thanked: 17572 times
- Been thanked: 16690 times
Peter,
I like the way you have rectangled off the active regions and prominences on the GONG image that you have imaged yourself. Nice idea!
And very nice images too!
- Has thanked: 1262 times
- Been thanked: 1057 times
Great session, Peter!
You're near the limits with 8800 fl and it came out very well!
I imaged the same plot at the same time with C11, this is really cool to see and compare the results with pleasure here on SC.
Thanks!
Leo
Thanks!
Leo
- Has thanked: 691 times
- Been thanked: 640 times
Holy moly, those closeups The 3-pane comparison is also v interesting, the middle one is definitely the best of the 3. Thank you for sharing!
Thanks, Peter, for the detailed explanation and the helpful three-pane image!
Your term „worminess“ is spot-on! My attempts to sharpen high resolution h-alpha images so far come out either too wormy, like this one:
or too soft, like this:
I‘ve also tried to use wavelet sharpening a couple of times, i.e. the wavelet tools in Registax, but so far with no acceptable results. The images I tried to sharpen with Registax showed artifacts much worse than any worminess from LR deconvolution and certainly looked nothing like your smooth and still detailed middle pane. I didn‘t know that different implementations of wavelets can make a real difference, so I will take a look at Astra Image and give wavelet sharpening another try, thanks for the suggestion!
Frank
Frank
- nicspenceryork
- Has thanked: 5852 times
- Been thanked: 1256 times
Wow amazing images Peter and really good example of sharpening which is very helpful,
Nic
Nic
