Solar N200/F4 (176/F4.5) + Quark Chromo + D-ERF 180mm + ASI174M
- Has thanked: 4219 times
- Been thanked: 3818 times
The very first light on the test set. Uncollimated Newton without adjustments and apertures.
I wanted to test whether such a combination would bring a usable result. Seeing was bad, Quark set by guesswork, but the first photo suggests it should work. Be forgiving.
- detail
- N1.jpg (1.28 MiB) Viewed 2710 times
- SunN200a.jpg (956.06 KiB) Viewed 2712 times
- SunN200b.jpg (920.08 KiB) Viewed 2712 times
- SunN200c.jpg (627.06 KiB) Viewed 2712 times
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: Solar N200/F4 (176/F4.5) + Quark Chromo + D-ERF 180mm + ASI174M
Good luck!
I've not seen this when tried before work with any prolonged success, maybe you will be the first!
I like to walk untrodden paths all my life.
- Been thanked: 4340 times
Excellent results for the setup...well done
I was able to get my quark combo to work on a 150mm newtonian, but it wasn't well suited to put Newtonian in the observatory so I didn't pursure the idea. Good luck with yours!
New configuration. N200/F6, (176/F6.8), D-ERF1800mm, LS80DSII + Quark + IMX432. Very good for prominence in right colors.
- ss7b.jpg (622.09 KiB) Viewed 2594 times
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
nice picture ,
you can give a detailed photo of the last assembly
sorry for my English translators google
The assembly is disassembled and will be reconstructed as a lattice structure.
As soon as I finish it, I will post the photos here.
- Has thanked: 714 times
- Been thanked: 496 times
For some unknown reason, the netwon tubes are more prone to instrumental turbulence than closed tubes (HaT, refractors).
I would suggest to rebuild your setup as an open system, like a truss, if you have the chance to do so.
Probably the DERF let 100nm passing through (I don't know the exact spectral curve), so you can figure how much heat will pass through.
Your mirror coating is probably of standard type -> It will absorb ~8% of the incident heat.
Then reflect toward the secondary, which will also absorb ~8%.
CS
Alex
CS
Alex
- Has thanked: 8418 times
- Been thanked: 8165 times
The last image is a beauty. Nice one.
I am building a new telescope as an open tube. The primary mirror 200mm/F6 has a coating of 98% reflectivity, the secondary 96%. In addition to the main D-ERF 180mm, the set also includes a 2" ERF LUNT. The central shading will be reduced by using a 44mm diameter mirror. The Lunt LS80 will be used as a double etalon in combination with Quark.
Sorry for my poor english.
- OlegLviv
- Has thanked: 882 times
- Been thanked: 907 times
Am wainting your new tube because wants too big aperture 150mm hand made! Your English normal friend how my=))) I want buy ERF but 800$ and tax more for me.....
https://www.facebook.com/oleg.lavigne/
https://www.astrobin.com/users/RamonLviv/
https://www.astroclub.kiev.ua/forum/ind ... ic=46758.0
Telescope: TS 152/900/Bresser 102/1350
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Camera: Apollo Max 432M/ Apollo Mini 429M/Player One Mars II 462M/QHY 290MM
Mounh: 2xSky Watcher AZEQ6
Telecentric Lense: Televue Powermate 2/2.5x/4X/5X
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
It's quite an expensive project. 180mm D-ERF 1700,- Euro, mirrors 600,- Euro, duralumin 450,- Euro, two etalons 4,000,- Euro and my work is priceless.
This is the cause of the delay of the solar N200/F6 project. Today I finished a new mount with harmonic gears for my friend and tomorrow the Newton project starts.
- EQ-HD5.jpg (783.68 KiB) Viewed 2397 times
Now is Sun missing only.
N179/F6.5 .
N179/F6.5 .
- ns3.jpg (1.16 MiB) Viewed 2242 times
- ns2.jpg (1.24 MiB) Viewed 2242 times
- ns1.jpg (1.63 MiB) Viewed 2242 times
- Has thanked: 1 time
- Been thanked: 2714 times
Very nice OTA. Well done !
Very cool setup!
