Focusing with SharpCap
HAL
Been thanked: 133 times
Post by HAL »
Anyone have any tips or tricks for achieving a really good focus with SharpCap?
rigel123
Has thanked: 8547 times
Been thanked: 8781 times
Re: Focusing with SharpCap
Post by rigel123 »
Focusing with any program, start with either the limb or a sunspot if available. Crank up Gamma to get high contrast and get the sharpest image you can. If seeing is really poor (the sun looks like it is under water) you are going to have a tough time getting any focus at all.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Has thanked: 20757 times
Been thanked: 10442 times
Sorry, i'm a firecapture kinda guy...
rsfoto
Has thanked: 9694 times
Been thanked: 5760 times
Post by rsfoto »
HAL wrote: Tue Aug 02, 2022 1:01 pm Anyone have any tips or tricks for achieving a really good focus with SharpCap?
Focusing on the Sun is a question of observing the changes over the short time.
I really never succeeded with any automatic focusing algorithm.
Get a motorized focuser and observe the Sun, as Warren said, sometimes under water and sometimes over the water. Find focus manually until you have brief moments of sharpness and ignore the underwater periods.
Alto
Has thanked: 962 times
Been thanked: 335 times
Post by Alto »
I sometimes manage to get something with the seeing monitor option - snag is if I set a threshold it'll often not get back to it.
Trial an error me thinks - after all it is called lucky imaging....
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Use your zoom feature in SharpCap to aid in focusing. Run it up to 100 percent. It helps me focus.
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
I also use Firecapture. It helps to focus at 200%
Rusted
Has thanked: 8114 times
Been thanked: 1941 times
Post by Rusted »
I use SharpCap and my home made, electric FT focuser.
It uses a so-called Skywatcher DC gearbox motor and belt drive to the fast motion knob.
The motor support plate is clamped to the stainless steel band behind the focus knob.
The belt allows slippage when manual control is needed to move the focuser rapidly a long way.
Mouse control in slow motion is controlled in the drop down box on the monitor.
Easily adjustable in size of steps or continuous motion. With reverse of course.
I move very slowly inside and outside of focus using a HiTecDC Focus box and its driver/software.
https://www.hitecastro.co.uk/index.php/ ... focus.html
This usually works by finding the highest contrast on my 27" monitor. But there are times... :roll:
P1460740 focuser crop.JPG (86.9 KiB) Viewed 583 times
Jordan Konisky
Has thanked: 386 times
Been thanked: 270 times
Post by Jordan Konisky »
I am going to give the SharpCap autofocus tool a try using the Fourier analysis mode. Does anyone have any experience with it?
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
I proceed the same way as rsfoto.
Furthermore, I monitor the focuser lower and higher positions (in step in my case), where I'm sure that I'm out of focus in both directions.
Generally, I then navigate between these min and max values.
CS
Alex
Alto
Post by Alto »
Try, also, stretching the histogram - that'll help with the contrast. At least sometimes..... Otherwise I do as others, keep moving either side of focus until I can't get it any better ( seeing permitted ). Electronic focuser is a godsend - at least you don't normally have to wait for the 'scope wobble to settle down....
Call me Geoff.
rsfoto
Post by rsfoto »
rsfoto wrote: Tue Aug 02, 2022 3:18 pm
Honestly I was just nosy ... :lol:
I open the roof, slew to the Sun, go for a coffee, wait 30 minutes and I do not even need to adjust focus again ... in both cases H-alpha and White Light
That is the advantage of having a permanent installation.
Sorry, the older one gets, the lazier one gets
:oops:
That sounds so nice, Rainer.
Alto
Post by Alto »
I find WL and CaK relatively "easy " in comparison to Ha!
I prefer to set up, slew, then enjoy a fine wine indoors at the pc. Mind I've been caught out a time or two by a shower!
Call me Geoff.
