Help! Lunt 80 arrived and I caught AP bug
BGazing
Has thanked: 16 times
Been thanked: 13 times
Post by BGazing »
OK, my Lunt 80 finally arrived, it was a bittersweet experience which I plan to explain in more detail in a CN thread, while I wait from Lunt and vendor to reply to a couple of problems that will need fixing (bad FTF, speck which seems to be inside of the doublet lens, missing caps, marred etalon anodizing during transport.
Other than that, the views are astonishing, I finally understand what a good etalon is and how convenient is a dedicated solar scope.
Now for the problem. I was always a visual guy and AP did not intrigue me, although solar was intriguing as it is so dynamic and I often wish to share what I see. A friend, who does only AP, was trying to convert me for years to the dark side, and finally managed to dump his ASI 120 mono 'to play with' while I am in countryside for a couple of days. I made a mistake and accepted.
What I have found out was that doing Ha AP was simple (I watch mono, switch to bino, then decide I will make a quick acquisition) and then the fun begins. Quite addictive and fits into my observing rhythm, it is not like you have 7hrs exposition at a dark site and abandon visual. He also dumped PIPP, Autostakkert and Registax on me and...that is it. I never did any of this stuff.
So I played, realized that focusing on prom is more difficult, that gains and exp on surface and proms are so apart, that I need to go darker, that he forgot to unlock full speed on the camera in max mode, that I should stack less images, etc. Also I just now realize that PM2.5 and this configuration do not play well because of NR and because of the oversampling (had to learn what that is).
Below are a couple of my firsts tries, that huge prom in varous stages and then some ARs and a flare today. I would most appreciate any suggestions you have - what should I pay attention to? Is this camera adequate long term, should I be aiming for something with smaller pixels? I use alt-az mounts exclusively (AZGti and Evolution, soon to acquire Rowan 100), my other scope suitable for some play on say Moon is Tak 100 (f/7.4). Any particular processing tricks? I do PIPP, ask it to halve the number of frames (I usually take 600-1000, but my FPS was usually below 30 when using full res because camera was capped) then go to Autostakkert, get as many stabilizing points, analyze and dump everthing but the best bit. Then play in Registaxx although I do not know what a particular wavelet does. :)
povrsina 5 avg.jpg (319.12 KiB) Viewed 257 times
BGazing
Re: Help! Lunt 80 arrived and I caught AP bug
Post by BGazing »
Some more...
2 (2).jpg (432.48 KiB) Viewed 256 times
BGazing
Post by BGazing »
Final one..
04 avg 22 (2) - Copy.jpg (24.56 KiB) Viewed 255 times
Radon86
Has thanked: 456 times
Been thanked: 385 times
Post by Radon86 »
Hello, I do not own a Lunt, but if I were you, I would consider not using the scope at all, and ask for a refund or exchange for a better scope !!
On your imaging, I would not hurry.
A few things are; a decent laptop with an SSD drive (NVME speed) and at least i5 quad core fast processor and 16 GB RAM.
You should also review the image scale so you are sampling at the correct image scale for your telescope and camera sensor pixel size.
And imaging takes time to learn. Don't expect things to work first time!
Please wait for good conditions, don't image in boiling heat or blustery conditions etc.
Best of luck.
Magnus
BGazing
Post by BGazing »
Okay, watched Marty's tutorial but basically aped most of it without understanding what is going on. The end result is OK despite having a different acquisition. Other questions remain, though.
disk plus protuberanca.jpg (342.57 KiB) Viewed 225 times
Rusted
Has thanked: 4321 times
Been thanked: 1392 times
Post by Rusted »
Your last image is pretty but very over-sharpened. Typical of Registax. Try using ImPPG instead.
Aim for a far more natural appearance without all those uniform artefacts.
This advice was given to me here and I value it as causing a major improvement in my own imaging.
It hurts to be criticised when you are just beginning at imaging but you asked for advice.
Hopefully you will see this as constructive advice. Your instrument shows huge promise.
As do your early results.
You don't say where you are based. How long did you have to wait for your Lunt?
H-alpha: Baader 160mm D-ERF, iStar 150/10 H-alpha objective, 2" Baader 35nm H-a, 2" Beloptik KG3, PST etalon, Lunt B1200S2, Assorted T-S GPCs, ZWO ASI174.
Has thanked: 11246 times
Been thanked: 5513 times
Welcome to the forum!
My advice at this stage, ditch PiPP and Registax, stack in AS3 and sharpen in ImPPG.
BGazing
Post by BGazing »
marktownley wrote: Sat Aug 06, 2022 7:07 am Welcome to the forum!
Thank you, the one up there was touched upon by ImPPG. I already have AS3 if you mean Autostakkert, any particular reason why I should ditch PiPP?
BGazing
Post by BGazing »
Rusted wrote: Sat Aug 06, 2022 3:44 am Your last image is pretty but very over-sharpened. Typical of Registax. Try using ImPPG instead.
Thank you, that is exactly the criticism I was looking for. :)
What are the 'uniform artifacts' you speak about?
I am based in Serbia, I ordered from the US and waited about 10 weeks. EU prices are much higher, even with the US transport.
Rusted
Post by Rusted »
I am glad you saw my criticism as constructive.
The artefacts are an overall spottiness. Caused by over-sharpening the image in an attempt to bring out more detail.
An unnatural, uniform texture applied to every part of the image. It remind me of old-fashioned newsprint.
Newspaper images were built up from dots. Enlarging such an image just makes the spots more obvious.
Here is an example from Alexandra:
https://www.flickr.com/photos/alexandra ... ed-public/
BGazing wrote: Sat Aug 06, 2022 7:41 am
PiPP only sorts images by global quality rather than local (alignment point) quality, you will get a better quality result.
Radon86
Post by Radon86 »
Very nice work so far, a good start. You have a Lunt 80mm solar telescope, amazing !
Magnus
BGazing
Post by BGazing »
Radon86 wrote: Sat Aug 06, 2022 11:03 am Hi,
Magnus
I know...I am still stunned by the views. :)
BGazing
Post by BGazing »
Okay, tried what you have suggested, I think this is a bit better. Too bad I did not do the acquisition at the best settings and did not know that my FPS was capped at 30 for some reason.
sredjeni disk i protuberanca 4avg take 2.jpg (500.87 KiB) Viewed 130 times
sredjeni disk i protuberanca 4avg take 2 inverted.jpg (503.88 KiB) Viewed 130 times
BGazing
Post by BGazing »
Rusted wrote: Sat Aug 06, 2022 8:12 am I am glad you saw my criticism as constructive.
Is this the right direction?
