Full Disk Still of large prom on East Limb (rotated 90 degrees CW for viewing) Animation
Astrobin Link to full resolution
So the animation is made by capturing 500 frames as an AVI every 30 seconds. I did this over an hours time so ended up with 120 individual AVI's to process. These were then processed in Autostakkert to produce 120 TIF's which were then processed in ImPPG. All 120 TIF's were then also aligned in ImPPG and then imported into Photoshop to be cropped and turned into a GIF. I set a frame rate of .05 seconds so the resulting animation runs for about 7 seconds. I think the file size was around 7mb for this particular animation which I post on my Flickr site as well as Astrobin. I then imported a link to the file so it plays on Solar Chat. For an in depth look at how I produce an animation you can watch the tutorial I made about 2 years ago here: https://youtu.be/AI2PGDVrxk0
Thanks Stu!
thanks thats greatrigel123 wrote: ↑Sat Aug 06, 2022 10:50 amSo the animation is made by capturing 500 frames as an AVI every 30 seconds. I did this over an hours time so ended up with 120 individual AVI's to process. These were then processed in Autostakkert to produce 120 TIF's which were then processed in ImPPG. All 120 TIF's were then also aligned in ImPPG and then imported into Photoshop to be cropped and turned into a GIF. I set a frame rate of .05 seconds so the resulting animation runs for about 7 seconds. I think the file size was around 7mb for this particular animation which I post on my Flickr site as well as Astrobin. I then imported a link to the file so it plays on Solar Chat. For an in depth look at how I produce an animation you can watch the tutorial I made about 2 years ago here: https://youtu.be/AI2PGDVrxk0
Hope this answers your question!
