Baader ND3.8 1m roll expression of interest - Update
Has thanked: 17888 times
Been thanked: 8887 times
Please add your name to the list if you would buy a roll. Let's see how many people we can get (bit like a petition) to write to Baader :)
I'm in
Has thanked: 1 time
Been thanked: 2725 times
Re: Baader ND3.8 1m roll expression of interest
Post by christian viladrich »
Excellent Alexandra ! I'll pass the information to others.
On my side, I am interested in 5 rolls.
Has thanked: 1 time
Just as a reminder, here is what you can get with a C14 and sheet of Astrosolar 3.8 :
http://astrosurf.com/viladrich/astro/so ... UT-red.jpg
http://astrosurf.com/viladrich/astro/so ... 14-red.jpg
Cameras have largely improved since then.
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
I'm also interested. It would be nice if the roll is 25 cm or 30 cm wide.
My software:
My images
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Hi All...
Count me in for the large sheet to be able to make a full aperture filter for my C14.
DavidP
Has thanked: 147 times
Been thanked: 288 times
Post by DavidP »
I’ll buy some
Has thanked: 20732 times
Been thanked: 10427 times
Yeah, i'll buy some too.
Don't forget though people, if you have an ERF for your cat/mak/rct etc you can use this in conjunction with a solar wedge to image in WL, I have done this with my HaT in the past.
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Absolutely. Would be nice to make a full aperture sheet for my C9.25.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 1 time
Hello Alexandra,
I started a pool on a French forum here :
http://www.astrosurf.com/topic/152586-e ... 38-de-1-m/
LauraMS
Has thanked: 55 times
Been thanked: 81 times
Post by LauraMS »
I would be in for three roles (1m each)
Excellent Christian, we will give it a while then add the numbers up together :) I wonder what their minimum order would be?
Has thanked: 1 time
Hello Alexandra,
Maybe we can pass the info to Cloudy Night Forum ? I don't know whether this is compatible with their rules ?
OK so far we have:
1 Alexandra Hart
5 Christian Viladrich
1 Filip Szczerek
1 Brian Coville
1 David P
1 Mark Townley
1 Jochen Maes
3 Laura MS
? Nigella Bryant (need to contact her)
2 chonum
1 Sauveur
2 astrovicking
1 messier63
2 cg16ang
1 silvietto
2 AlSvartr
2 JPMasviel
2 XavS
1 niborevad
1 banjo (Paul)
1 marco91
2 astrolamine
2 zorgdotnl
1 Pascal Tamburini
1 pascal_77
? Mehdi
1 jean guinet
1 Jean-Marc_M
1 allhoest
41 TOTAL
Need to check translation, I don't think EricS83 is wanting 26 rolls, does Mehdi want one?
Has thanked: 1 time
Hello Alexandra,
Eric83 was just summing up the current total.
Not sure Medhi wants one. Don't count any or him.
Alexandre Lhoest is going to launch a similar pool on German language forum(s).
Christian
TareqPhoto
Has thanked: 607 times
Been thanked: 402 times
Post by TareqPhoto »
I really prefer a mounting ring with those sheets rather than me cutting it and DIY it, if anyone is expert to make a precise one for my scope diameter so i just place/mount on the scope like gloves,.... I AM BIG INTERESTED IN then.
I bought the EMC solar filter for my C11 and swapped out the ND5 for ND3.8 for imaging.
https://astrograph.net/epages/www_astro ... ht_Filters
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
Hello Alexandra,
Dear German members,
Thank you Alexandra for launching this call.
As Christian mentioned, I'm ready to rely your initiative to the German "astronomie.de":
https://forum.astronomie.de/forums/sonne.170/
I must say that I'm not a German citizen and I would prefer that a German member of solarchat takes the hand here. If no one does, then I'll do.
How do you figure to "retail" the pieces?
Christian will group the rolls for France,
you (Alexandra) would take care for the UK?
If no German member takes the hand, I could take care for Germany?
Or would you suggest that each of us get the roll directly from Baader?
Beside note: I wish a filter of eg ND2.5 instead of 3.8.
CS
Alex
Alex,
It was more a petition style, we need to convince Baader that it is worth their while to make a run and that enough people would be there to buy it. We would need to buy from Baader if they made it.
However, we are still unsure how much a run would be, is it 50m or 1000m? At least if we could generate enough interest we could convince them to manufacture a run and then we could all buy them.
LauraMS
Post by LauraMS »
I strongly support Alex' notion of ND=2.5 or so. This would allow to go for lower bandwidth filter (e.g.G-Band filter) in connection with short exposure times. However, it may be less universal in use because thermal issues may get more severe than at ND 3.8.
galaxie427
Has thanked: 193 times
Been thanked: 16 times
Post by galaxie427 »
Hello Alexandra,
Please put me down for 1 roll (assuming 50x100cm).
btw, In checking about the 3.8 film last summer with Alpine Astro here in US, I was told the film is manufactured in 1,000 meter runs.
Thanks so much for this opportunity!
Has thanked: 1 time
Montana wrote: Thu Mar 10, 2022 2:11 pm Alex,
Indeed, I had a talk with M. Baader about 4 years ago about the Astrosolar film. It was at a Astro Meeting in Paris. My understanding was that the manufacturing of the solar film was very difficult, and to launch a new run was more a question of several hundreds of meters.
Has thanked: 1 time
LauraMS wrote: Thu Mar 10, 2022 2:55 pm I strongly support Alex' notion of ND=2.5 or so. This would allow to go for lower bandwidth filter (e.g.G-Band filter) in connection with short exposure times. However, it may be less universal in use because thermal issues may get more severe than at ND 3.8.
Sure Laura. But first let's see how many people would be interested in a ND3.8 and check with Baader if the count is large enough for a new run
allhoest
Post by allhoest »
Hi!
Regarding thermal issue under with a ND2.5, I would not be afraid.
Many of us use non aluminized mirrors with ~4% of reflection of the incoming flux without major problem. Maybe at native focal ratio, a filter can be added. Along with barlow/telecentric, there is no thermal issue.
Regarding the 1000m run, I don't really see the problem.
The rolls are 1x0.5m, so the nominal width is 0.5m.
With 0.5m, they can sell 2x 250mm pieces, etc.
I have posted the "expression of interest" on astronomie.de. Let's see...
https://forum.astronomie.de/threads/umf ... ck.321759/
CS
Alex.
LauraMS
Post by LauraMS »
[quote="christian viladrich" post_id=326365 time=1647000376 user_id=3037]
[/quote]
sure Christian .. But may I remind you that Alex brought that idea into this thread? I am just responding.
Hi Alex,
Does anyone on the astronomie.de express an interest?
I've just sent a 'Contact us' request.
We have 39 astronomers with a pledge for 51 rolls and 2 provisional. I couldn't find any responses on the German site.
I'll post the response from Baader here when I receive it.
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
I can be interested depending on the price. I have a crazy project in mind. I spoke a couple of weeks ago with Bob Luffel at Alpine and he told me Baader may consider a new run early next year in view of the upcoming 2024 solar eclipse. I have down to contact him next January.
Has thanked: 1 time
Hello Alexandra,
On Astrosurf French forrum, we are up to 39 rolls.
I don't see any response on the German forum, but I don't read german. I'll ask Alex to make sure.
Cloudy Night never answered my message asking their authorization to pass the info.
vineyard
Been thanked: 659 times
Post by vineyard »
Hi, if its not too late to join the list, then yes please count me in. Thank you!
alpenglow
Has thanked: 37 times
Been thanked: 13 times
Post by alpenglow »
Yes please!! Cheers!
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Thanks a lot Alexandra for your efforts!
Montana wrote: Sat Apr 09, 2022 12:56 pm I've just sent a 'Contact us' request.
I have missed your recent post on astrosolar when you sent it out and today Christian kindly let me know about these efforts by you and him.
Therefore, if there is still an opportunity, please add me in the list for one roll.
After my first solar scope last year, I recently saw my second dream of two decades coming true. I received my C14 Edge! :-) :-) :-)
I am really excited as you can imagine. I would like to be able to use it for WL in the rare cases of perfect seeing...
Christian's solar photos are so inspiring that I would love to try.
Hopefully Baader will respond positively at the end.
Thanks once more,
Alexandros
Alexandros
Greece
That's fine Alexandros. It is now two weeks since I wrote to them and not even a reply saying anything at all. There are more than 40 astronomers waiting patiently for a reply :(
I am very disappointed to say the least. I think it is more polite to say, sorry but no, than absolutely ignoring me.
Does anyone have an email address for Mr/Ms Baader?
Re: Baader ND3.8 1m roll expression of interest - Update
Finally an update which I will share in full for you. So we need to be patient and hopefully it is coming soon :) Thank you Baader :)
Dear Ms Hart,
please take our excuse for the belated reply. As most everyone we are overwhelmed by supply problems and exploding prices for raw materials. In fact we are struggling to keep our Baader products available without too many gaps in certain product families - Astrosolar film being one of them.
As mentioned to Mr Viladrich, we do thank you and the group for contacting us on this matter of large size Photosolar-Film in OD 3.8.
Unfortunately at this time we are unable to fill such a request. It may take us until end of this year to enable us supply such large sizes in OD 3.8 again. We dearly hope the supply issues that we face will improve within coming months. We are working on a method to increase safety while offering this OD.
There are numerous stages in the production process that need to be observed most carefully, in order to maintain optical quality and freedom from astigmatism. This film just looks so simple, but in fact it is a severe task to produce it in true optical quality. We will gladly inform everyone on our website as soon as we are successful.
We will definitely not forget this inquiry and hope by end of this year latest, to being able to serve you and the group,
Please bear with us and be thanked again for your interest.
Thomas Baader
BAADER PLANETARIUM GMBH
Has thanked: 1 time
Very good news :-)
Thanks a lot Mr. Baader !
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
I would be interested in 2 rolls.
How much would 1 roll cost approximately.
Woukd it be ordered from Baader UK, as Baader in Germany charge a lot in postage.
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
They need to make it first Magnus :)
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Hi Alexandra, yes, I'd love to have some of the large baader Nd 3.8 solar film.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Stardust5858
Montana wrote: Wed Mar 09, 2022 8:17 am OK so far we have:
1 Alexandra Hart
1 Filip Szczerek
1 Brian Coville
1 David P
1 Mark Townley
1 Jochen Maes
3 Laura MS
1 Nigella Bryant (need to contact her) just back, many thanks.
2 chonum
1 Sauveur
2 astrovicking
1 messier63
2 cg16ang
1 silvietto
2 AlSvartr
2 JPMasviel
2 XavS
1 niborevad
1 banjo (Paul)
1 marco91
2 astrolamine
2 zorgdotnl
1 Pascal Tamburini
1 pascal_77
? Mehdi
1 jean guinet
1 Jean-Marc_M
1 allhoest
41 TOTAL
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
DavidP
Post by DavidP »
Has anyone tried imaging with the ND5?
What kind of exposure times are required with this?
GreatAttractor
One can use ND 5, but it becomes suboptimal when you push the setup towards optimal sampling and contrast. E.g., at f/16 and with Solar Continuum (which is quite narrow at 8 nm), ND 3.8 led to about 7 ms exposure (at zero gain, with histogram at 80-90%) with the ICX445 sensor (newer ones might be better by a few 10s of %, but that's it). ND 5 would require about 16x longer, which in less-than-perfect seeing would be unworkable (on the other hand, on new sensors you can increase gain a lot and still not get too much noise).
If all you can get at the moment is ND 5, by all means give it a go (and don't use very narrow filters; e.g., use a "visual" green filter instead of the Solar Continuum).
My software:
My images
Yes, it was impossible :(
Arrakis97
Has thanked: 350 times
Been thanked: 306 times
Post by Arrakis97 »
I will buy 1 Baader OD 3.8 100x50 cm.
Carlo
vineyard
Post by vineyard »
GreatAttractor wrote: Wed Jun 15, 2022 7:44 pm If all you can get at the moment is ND 5, by all means give it a go (and don't use very narrow filters; e.g., use a "visual" green filter instead of the Solar Continuum).
I'm not a v good imager, but in case its of interest DavidP here - viewtopic.php?t=36658 - are some images I took 2 days ago w ND5 film. I used an Astronomik 642nm long-pass filter (ie a broad band pass as GreatAttractor also says). Cheers
proceau
Post by proceau »
I will buy 1 Baader OD 3.8 100x50 cm for C11
Radon86
Post by Radon86 »
Dear Alexandra/Montana,
Is it time to order these ND3.8 films yet ?
I think I would like 1-2 rolls.
Thanks.
Magnus
According to the statement of Mr Baader above he quotes "We will definitely not forget this inquiry and hope by end of this year latest, to being able to serve you and the group" so I don't think we are are at the end of this year yet :)
shadowchaser
Has thanked: 18 times
Been thanked: 4 times
Post by shadowchaser »
Montana wrote: Thu Aug 18, 2022 6:21 pm According to the statement of Mr Baader above he quotes "We will definitely not forget this inquiry and hope by end of this year latest, to being able to serve you and the group" so I don't think we are are at the end of this year yet :)
Hi Alexandra!
I am interested in one of these sheets of film for my 12" Meade. Is Baader going to put them on sale to the general public or just for this group? Because I live in Argentina and I don't know how they would be shipped.
Another question, are they only going to sell the 100x50 cm sheets or also the filters already mounted on a frame?
Thank you very much!
Dear Shadowchaser,
I would presume that it would be on sale for the general public, you would need to buy direct from Baader. We got this expression of interest going to show Baader that if they produced a run they would have enough people who would buy it. It was an incentive. So order through your normal channels. Usually you have to buy a filter with a ND5 in, then buy the film and replace the ND5 with the ND3.8. I think they sell the filters cells with ND5 fitted only.
shadowchaser
Montana wrote: Fri Aug 19, 2022 7:55 am Dear Shadowchaser,
Thank you very much Alexandra for your answer!
I hope to get one of these filters, I have one for my Maksutov 180 and it gives me very good results.
InFINNity-Deck
Post by InFINNity-Deck »
Hi Alexandra,
could you please add me to the list?
I am struggling quite well with ND5.0 on a C11, but ND3.8 must mean a great improvement.
with kind regards,
Nicolàs
http://www.dehilster.info/astronomy/sun.php
https://www.dehilster.info/astronomy
Mount: 10Micron GM3000HPS, OTAs: SkyWatcher Esprit 80ED and Esprit 150ED, Celestron C11 XLT EdgeHD, Lunt LS80THA single stack, GTT60 (60mm aperture Galilean Type Telescope), SkyWatcher Explorer 300PDS, Bresser Messier 130/650, Cameras: ZWO ASI1600MM Cool, ZWO ASI174MM, ZWO ASI290MC, QHYCCD QHY163M, Eyepieces: TeleVue Ethos 6mm, 8mm, 10mm, 13mm, 17mm, 21mm, PanOptic 41mm, Barlows: TeleVue 2x & 4x PowerMate
