Ha Sun September 10, 2022
- Has thanked: 9145 times
- Been thanked: 6027 times
Hello all: yesterday morning again good seeing so I was trying to take advantage of the good conditions and use the HaT scope. First time I tried it with the TZ-4 and Quark Combo, followed by Airylab 2.7x and SS filter. I initially used the Apollo Max 432 camera with still some Newton Rings problems , then switched to the FLIR 174 camera and rings disappeared. Finally a couple of prom shots. Thank you for looking !
- 090011 Active region.jpg (207.47 KiB) Viewed 475 times
- 090011 Active region color.jpg (232.2 KiB) Viewed 475 times
- 1233-4 AR3096.jpg (125.09 KiB) Viewed 475 times
- 1227-3 AR3096.jpg (104.93 KiB) Viewed 475 times
- 1235-3 AR3092.jpg (88.43 KiB) Viewed 475 times
- 090556 AR3092.jpg (181.96 KiB) Viewed 475 times
- 090701 chromosphere closeup 2 inverted.jpg (168.21 KiB) Viewed 475 times
- Twin proms.jpg (76.7 KiB) Viewed 475 times
- Twin proms color.jpg (58.74 KiB) Viewed 475 times
- 093520 triangular prom.jpg (46.08 KiB) Viewed 475 times
- 093520 triangular prom color.jpg (40.57 KiB) Viewed 475 times
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Re: Ha Sun September 10, 2022
Nice set of images, Franco
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Has thanked: 17581 times
- Been thanked: 16697 times
These are beautiful Franco! All well done and all show really nice detail. I really like the prominence ones. Which camera did you use on those?
- Has thanked: 1680 times
- Been thanked: 1167 times
Wonderful images, the proms look fantastic
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
Thank you Starhugger, Jordan, James and cybermayberry for your nice comments. James: I used the FLIR 174 camera for the proms.
- rigel123
- Has thanked: 8316 times
- Been thanked: 8544 times
Great shots Franco!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 17672 times
- Been thanked: 8793 times
These are absolutely terrific I wish I had bought the FLIR version of the 174
- Has thanked: 8418 times
- Been thanked: 8165 times
Great images, Franco. Lots of fine details.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Very nice, Franco. You definitely made the right choice in bringing out the big toys.
- Has thanked: 20442 times
- Been thanked: 10248 times
You got a great run of images here Franco!
