Ha belated images / May 5 / C8 EdgeHD / double stack Ha
- Has thanked: 1 time
- Been thanked: 2713 times
Here are some old Ha images taken on May, 5 with the C8 EdgeHD:
http://astrosurf.com/viladrich/astro/so ... -SMn35.jpg
A group of sunspots hardly visible with the double stack filter, since it is nearly completely covered by fibrils :
A set of prominences, some shows very fine details while others look fuzzier:
http://astrosurf.com/viladrich/astro/so ... -PE06A.jpg
Clear skies
Christian
Clear skies
Christian
- OlegLviv
- Has thanked: 881 times
- Been thanked: 907 times
Re: Ha belated images / May 5 / C8 EdgeHD / double stack Ha
Very very good!
https://www.facebook.com/oleg.lavigne/
https://www.astrobin.com/users/RamonLviv/
https://www.astroclub.kiev.ua/forum/ind ... ic=46758.0
Telescope: TS 152/900/Bresser 102/1350
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Camera: Apollo Max 432M/ Apollo Mini 429M/Player One Mars II 462M/QHY 290MM
Mounh: 2xSky Watcher AZEQ6
Telecentric Lense: Televue Powermate 2/2.5x/4X/5X
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Oops, wrong place ...
Thanks Oleg !
Thanks Oleg !
- Has thanked: 4213 times
- Been thanked: 3812 times
Excellent photos. It can be seen that the diameter of 200mm will do its job. With my AR150/F6, I was only able to capture details when there was really exceptional seeing.
- ss3a.jpg (2.02 MiB) Viewed 389 times
- OlegLviv
I bought HD8 special for sun but dont buy ERF=))))
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Has thanked: 20435 times
- Been thanked: 10244 times
Super images as always Christian!
- Has thanked: 17572 times
- Been thanked: 16693 times
Superb work Christian. I would consider getting a C8EdgeHD vs a 152mm refractor.
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Superb again, Christian.
Thanks to all !
- Has thanked: 17667 times
- Been thanked: 8789 times
Absolutely exceptional I see that some areas of the prom are very detailed whereas other areas are soft. I have seen this before in my own images, I wonder if these areas are moving faster (motion blur) compared to other areas or whether it is just different structures within the prominences.
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Awesome images, Christian!
Every time I see images from your hand I dream of larger aperture :-) I do know however that it's more to more to it - like good seeing and acquisition and processing skills!
Arne
Arne
Thanks guys !
There was no difference at all in the result, meaning no motion blur. So, for some reasons, some prominences look a bit soft. Maybe we have overlapping structure along the line of sight ? I don't know.
This is a bit the same for the spicules visible at the solar limb. A few of them are moving very fast, but others remain very soft even if the duration of the film is reduced to 5 - 10 s, and others are very sharp.
Indeed Alexandra, this is something a bit puzzling. I investigated it by reducing the length of the film used for stacking by Autostakkert 3 to about 10 s. You can do it by choosing the option "limit" at the right of the "open" button"Montana wrote: ↑Thu Sep 15, 2022 2:07 pm Absolutely exceptional I see that some areas of the prom are very detailed whereas other areas are soft. I have seen this before in my own images, I wonder if these areas are moving faster (motion blur) compared to other areas or whether it is just different structures within the prominences.
