Flare with white light and 12nm Ha ... ? Thoughts.
steveward53
Has thanked: 1234 times
Been thanked: 1492 times
Post by steveward53 »
Just seen this over on CN forum , poster was skeptical , as am I ... :?
https://spaceweathergallery.com/indiv_u ... _id=188540
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
Has thanked: 20757 times
Been thanked: 10442 times
Re: Flare with white light and 12nm Ha ... ? Thoughts.
A stacking artefact more likely...
steveward53
marktownley wrote: Mon Sep 19, 2022 11:27 am A stacking artefact more likely...
Reply from Marty Wise on CN ...
"You can capture proms with wider bandpass filter systems. There's nothing behind them (space) that is brighter (ie, no photosphere)."
"You can see them with no filter at all, during an eclipse, because the disc is masked and there's nothing behind the prom."
if you're on here Marty could you elaborate please ... ?
Steve.
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Steve, are you aware of the Carrington event? https://en.wikipedia.org/wiki/Carrington_Event I caught that flare in H alpha It was bright.
Screenshot 2022-09-19 223037.jpg (276.95 KiB) Viewed 264 times
steveward53
Martin_S wrote: Mon Sep 19, 2022 12:27 pm Steve, are you aware of the Carrington event? https://en.wikipedia.org/wiki/Carrington_Event I caught that flare in H alpha It was bright.H-alpha_105531_lapl4_ap738sc.jpgScreenshot 2022-09-19 223037.jpg
You're doing well to still be typing if you caught the Carrington Event ... :lol:
Steve.
Martin_S
Post by Martin_S »
steveward53 wrote: Mon Sep 19, 2022 12:40 pm
Hmm yes , I need to improve my English grammar :lol:
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
So, Martin confirmed we had a small bright surge visible with a "narrowband" 12 nm Ha filtre.
Very interesting.
The Sun is full of surprise !
christian viladrich wrote: Mon Sep 19, 2022 1:22 pm So, Martin confirmed we had a small bright surge visible with a "narrowband" 12 nm Ha filtre.
Very interesting.
Indeed. I eat my words!
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
It probably would be possible in an off band Ha filter tuned high which shows more photosphere.
In a 12nm wide Ha filter it would indeed be a surprise. That was an intense one!! Martin's image shows some double limb and chromosphere too.
steveward53
DeepSolar64 wrote: Mon Sep 19, 2022 2:36 pm It probably would be possible in an off band Ha filter tuned high which shows more photosphere.
Martin's image is from a Hydrogen-alpha rig not a "white-light + 12nm Ha" set-up ... :lol:
viewtopic.php?t=38110
His chromosphere image from the same time is just confirming that there was indeed a flare and prominence there at the time ... :roll:
Steve.
