Sun before rain - October 8th
Lovely early morning Sun before the cloud and rain set in.
Sun at low altitude so images not as detailed as I'd like, but you take what you can get.
Apologies for not orientating the Sun correctly.
RichardJ
RichardJ
- Has thanked: 17845 times
- Been thanked: 16977 times
Re: Sun before rain - October 8th
Looks nice. I love the details, coloring and labeling of the active regions.
What equipment are you using?
Hi James,
Thank you.
Skywatcher Evostar 72mm scope , ZWO120MC camera and Teleview 3x Barlow for the close up.
I use an alt az mount and take AVIs as the Sun drifts across the field of view. Processed in Autostakkert and Photoshop CS5.
Not ideal but I only had a brief window of opportunity.
Richard.
Thank you.
Richard.
Richard,
Your tech is similar to mine. I have an Astro-Tech AT72EDII and a ZWO ASI178MM. 2x CeMax barlow. And unguided mounts imaging the same way. It's nice to not be alone in this way :-)
Hi James,
Sometimes keeping it simple is fun and it works.
- Rusted
- Has thanked: 8127 times
- Been thanked: 1943 times
Nicely crisp images!
Thanks for the clearly numbered AR image.
SpaceWeather wasn't very obvious on AR3112 & AR3116.
Now we know!
Now we know!
- Has thanked: 8544 times
- Been thanked: 8280 times
Very nice images and presentation, Richard.
- Has thanked: 20783 times
- Been thanked: 10464 times
That's a nice image Richard!
- Has thanked: 1640 times
- Been thanked: 878 times
- rigel123
- Has thanked: 8566 times
- Been thanked: 8800 times
Nice shot Richard! When I don’t have much time I set up on a Port-A-Mount and also just capture while the sun drifts through the FOV. It’s much easier with a tracking mount but it’s definitely doable!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Thank you. I also try and orientate the camera so as the Sun drifts across, it does so across the maximum side dimension of the camera chip. Gives me the maximum number of frames to process but I’m sure this is what most people do.
Richard.
Richard.
- Has thanked: 9307 times
- Been thanked: 6144 times
Richard,
Most people who use set ups like ours use them for visual observing. That’s certainly true for me.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Has thanked: 17970 times
- Been thanked: 8905 times
