Hi all,
Focused on the solar eclipse, I was almost going to miss the amazing ballet of the "almost sun" and its Galilean satellites. Fortunately, I saw the ephemerids the last moment and rushed to set the C14 to capture it. The seeing was good only in the start of the session, but the spectacle still keeps much of its beauty, I think.
In the beginning Io is to the right and later reappears suddenly to the left, because it comes out of the shadow of Jupiter. Europa (to the left) follows the larger Ganymede.
I post here one of the shots with the four out five members of the Jovian family and the most spectacular long animation further below. I was obliged to cut the animation in three parts, due to bad seeing in-between and also limited space in my hard disk.
Hope you will like it.
2022-10-26, Jupiter with Europa, Ganymede & Io, C14 Edge, Barlow 2.1x, ASI 462, 18_48_48 UTC by H- Alpha, on Flickr
2022-10-26, Jupiter with Europa, Ganymede & Io, Animation of 3h 38 min, C14 Edge, Barlow 2.1x, ASI 462, 18_44_48-22_22_54 UTC by H- Alpha, on Flickr
Best wishes,
Alexandros
Sunlit, 3h 38 min ballet in animation of Jupiter with Europa, Ganymede & Io, shadows and eclipse
Moderator: Montana
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Alexandros
Greece
Greece
- Has thanked: 17845 times
- Been thanked: 16977 times
Re: Sunlit, 3h 38 min ballet in animation of Jupiter with Europa, Ganymede & Io, shadows and eclipse
WoW, the sense of depth is amazing!
- Has thanked: 20779 times
- Been thanked: 10462 times
This is lovely!
I'll put in the sunlit earth section.
- Has thanked: 17970 times
- Been thanked: 8905 times
WOW it looks so 3 dimensional as if you were watching from a spacecraft. That's super
- Has thanked: 8543 times
- Been thanked: 8280 times
Absolutely superb, Alexandros. Beautiful work.
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Hi Alexandros, this is a magical sight, I can't even believe that it was taken off the Ground.
Ivan
Ivan
