small flare visible in Ha on October 5 - C8 EdgeHD
- Has thanked: 1 time
- Been thanked: 2725 times
Here are two belated images taken on October 5 with the C8 EdgeHD and a double-stack Ha combination. A small flage was visible :
http://astrosurf.com/viladrich/astro/so ... AR3116.jpg
Some area 1h30 latter :
http://astrosurf.com/viladrich/astro/so ... -SMn35.jpg
Then the flare intensity increased, as well as turbulence ...
BTW, does the following image display correctly on your screen ?
Clear skies
Christian
Clear skies
Christian
- Has thanked: 9307 times
- Been thanked: 6144 times
Re: small flare visible in Ha on October 5 - C8 EdgeHD
The image displays beautifully on my screen and it is superb ! I remember that day, the sun was very active.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
Thanks for sharing such wonderful images Christian.
- Has thanked: 20779 times
- Been thanked: 10462 times
Nice images Christian, I wish my seeing supported this. The third image does not show for me in the thread.
- arnedanielsen
- Has thanked: 6296 times
- Been thanked: 7308 times
Stunning result Christian!
Arne
Arne
- Has thanked: 4379 times
- Been thanked: 3976 times
Fantastic pictures. Bravo.
- Has thanked: 17845 times
- Been thanked: 16977 times
It looks really good on my iPhone13 Pro Max.
- Has thanked: 17970 times
- Been thanked: 8905 times
Wow, I also wish I could take images like this
The third image does not display for me either
Thanks to all !!
It seems I still have an issue when I try to post images instead of links. I know there was some issues with the protocoles used by Astrosurf. I have to check again with them.
Hi Christian: do you have an image of the setup, in particular the stacking of the two etalons ?
Thank you,
Thank you,
- Been thanked: 4971 times
Christian, it is because the astrosurf website does not have an SSL certificate, if you look at the web bar at the top there is no padlock by the address, it says 'not secure'. The forum only allows secure sites to link for security.
