Sun December 10, 2022
- Has thanked: 9319 times
- Been thanked: 6157 times
Hello all: yesterday a CaH and Ha session in a cold (for me) and sunny day. 34 Fahrenheit and sun elevation 15 degrees. A CaH closeup of AR3153, an inverted Ha mosaic of the most active area and a CaH FD. I am also posting a reduced format animation of some glitch that happened using Firecapture, that I thought was funny.
Clear skies to all,
Clear skies to all,
- 112029 AR3153 color.jpg (632.7 KiB) Viewed 2014 times
- 112029 AR3153.jpg (567.36 KiB) Viewed 2014 times
- Mosaic 121022 inverted color.jpg (3.68 MiB) Viewed 2014 times
- Mosaic 121022 inverted.jpg (2.22 MiB) Viewed 2014 times
- 114153 CaH FD color.jpg (1.31 MiB) Viewed 2014 times
- 114153 CaH FD.jpg (1.17 MiB) Viewed 2014 times
- 73xv4y.gif (2.24 MiB) Viewed 2014 times
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7323 times
Re: Sun December 10, 2022
Very nice set of images, Franco! Nice to see you at the Zoom meeting.
Arne
Arne
Thank you, great to see you too, Arne. Meeting was well attended with 17 people… hope to see your images again soon.
- Been thanked: 4900 times
- Peterm
- Has thanked: 1806 times
- Been thanked: 1565 times
Amazing set of detailed images Franco.
Lunt 80Tha S/S & D/S / B1800; Quark Chromosphere; SkyWatcher 120 Evostar; Celestron SE6; Celestron AVX; Berlebach Planet; ZWO174MM & 432MM & 533MM; Powermate 5X; Lunt Solar Wedge; Hinode SG; Airy Labs SSM
Astrobin: https://www.astrobin.com/users/PeterM/
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- Has thanked: 17853 times
- Been thanked: 16992 times
Excellent Franco. Again I absolutely love your CaH work!
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Lovely detailed images Franco, despite the cold.
The FC glitch is interesting but reminds us of some sort of video transition effect.
Clare & Peter
Thank you all for your kind words: we now have the first snow on the ground, not sure when the next imaging session will be
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Nice session Franco! I’ve seen something similar to the glitch you posted as well. Sometimes it is a problem and I have to restart things. I’ve always wondered if it was software, camera or cable issues!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Been thanked: 8906 times
Terrific CaH Franco, I like the first as the spot looks like a heart it was great to see you last night
Thank you Warren and Alexandra: it was great to see you both. Sorry we could not talk a bit more...
- Has thanked: 20813 times
- Been thanked: 10487 times
You got some great images here Franco!
- Has thanked: 8558 times
- Been thanked: 8290 times
Great images, Franco. CaH master
I agree. CaH master Franco is!
Thank you Mark, Stu and James for your comments, greatly appreciated.
- Has thanked: 612 times
- Been thanked: 404 times
As long as i really like that Ha solar images very much, i can't blind myself about that Ca K/H as well, it is amazing enough that i ordered the CaK module, and finally they shipped it so it will take a while, i hope i can get really nice results from it, so my question will be, how you and all others getting clean images of the sun without those dust bunnies or distractions happened in the raw captures? I tested my CaK filter with the wedge and it was so full of dust spots everywhere, i even couldn't tell the sun spot from dust spot as much.
Many here use flats to eliminate dust bunnies. I have not learned how to do that yet and I often use the clone stamp tool in GIMP to remove them manually though if there is a lot of them it's time consuming and the results often are not as good as I like. The best option is to keep your optics capped when not in use and to keep them as clean as possible. I find that difficult because I use my optics so very often.TareqPhoto wrote: ↑Sat Dec 24, 2022 10:33 am As long as i really like that Ha solar images very much, i can't blind myself about that Ca K/H as well, it is amazing enough that i ordered the CaK module, and finally they shipped it so it will take a while, i hope i can get really nice results from it, so my question will be, how you and all others getting clean images of the sun without those dust bunnies or distractions happened in the raw captures? I tested my CaK filter with the wedge and it was so full of dust spots everywhere, i even couldn't tell the sun spot from dust spot as much.
Hi James,DeepSolar64 wrote: ↑Sat Dec 24, 2022 3:52 pmMany here use flats to eliminate dust bunnies. I have not learned how to do that yet and I often use the clone stamp tool in GIMP to remove them manually though if there is a lot of them it's time consuming and the results often are not as good as I like. The best option is to keep your optics capped when not in use and to keep them as clean as possible. I find that difficult because I use my optics so very often.TareqPhoto wrote: ↑Sat Dec 24, 2022 10:33 am As long as i really like that Ha solar images very much, i can't blind myself about that Ca K/H as well, it is amazing enough that i ordered the CaK module, and finally they shipped it so it will take a while, i hope i can get really nice results from it, so my question will be, how you and all others getting clean images of the sun without those dust bunnies or distractions happened in the raw captures? I tested my CaK filter with the wedge and it was so full of dust spots everywhere, i even couldn't tell the sun spot from dust spot as much.
Taking flat frames is so easy to do, because i do DSO imaging so flat is very important there, i can do the same for solar imaging, but i still don't know how to use it in processing for solar, definitely i will learn how somehow.
I will try to keep my optics clean, and they are all or always capped when not in use, but i live in a kingdom of dust here so no matter how careful i am they find a way to my glasses, so i am sure i will clean more often, but i want to have ways to get the results clean anyway, hopefully it won't turn out as a headache and "Day"mare to me.
Tareq
Keeping them clean in a desert environment would be really difficult and then there is the threat sand/dust scratching the optics.
I am not in desert, but my country is dusty in general, but i can't keep dust away no matter, i might clean today and dust will get in the next time imaging, so as long i do imaging all the time dust will be there, in fact my Antlia Wedge was full dusty from the first time use.DeepSolar64 wrote: ↑Tue Dec 27, 2022 4:03 pm Keeping them clean in a desert environment would be really difficult and then there is the threat sand/dust scratching the optics.
That sounds like pollen in the summer months here. The fine yellow grains invade everything!!TareqPhoto wrote: ↑Tue Dec 27, 2022 5:11 pmI am not in desert, but my country is dusty in general, but i can't keep dust away no matter, i might clean today and dust will get in the next time imaging, so as long i do imaging all the time dust will be there, in fact my Antlia Wedge was full dusty from the first time use.DeepSolar64 wrote: ↑Tue Dec 27, 2022 4:03 pm Keeping them clean in a desert environment would be really difficult and then there is the threat sand/dust scratching the optics.
I can imagine!DeepSolar64 wrote: ↑Tue Dec 27, 2022 6:01 pmThat sounds like pollen in the summer months here. The fine yellow grains invade everything!!TareqPhoto wrote: ↑Tue Dec 27, 2022 5:11 pmI am not in desert, but my country is dusty in general, but i can't keep dust away no matter, i might clean today and dust will get in the next time imaging, so as long i do imaging all the time dust will be there, in fact my Antlia Wedge was full dusty from the first time use.DeepSolar64 wrote: ↑Tue Dec 27, 2022 4:03 pm Keeping them clean in a desert environment would be really difficult and then there is the threat sand/dust scratching the optics.
Well, i can't wait to use the new gear i ordered once they arrive beside the Quark i have, i hope i can image the sun quickly these days before the summer, i will try to keep them shiny and clean as possible.
