March 15th Ha Session
- Been thanked: 4434 times
Good day everyone...
I managed to have my first solar session in over two weeks this past Wednesday and was away the balance of the week for work which delayed processing and posting. I processed the images while I was boiling sap at the bush yesterday to get caught up This was a short session over lunch and not a lot of time to use more that the Lunt LS80T scope to image. First views at the eyepiece showed some nice activity with many filaments/AR's and and couple of impressive proms as well.
The first image is a full disk composite taken with the ASI1600MM camera+1.6x barlow through he DS Lunt LS80T/LS75FHa/B1800HJa solar scope: With limited time, I switched to the ASI174MM camera and 3x telextender to image in slightly higher resolution, and was able to assemble mosaics of the norther and southern disk: These last images are the larger proms that were found along the western limb: I would have like to spend more time to image in greater detail but I was glad that I took the time to get these.
- Has thanked: 4379 times
- Been thanked: 3977 times
Re: March 15th Ha Session
Very nice discs and detailed pictures of proms.
- Has thanked: 8559 times
- Been thanked: 8297 times
A great set of images, Brian.
Very nice.
Very nice.
- Petrus
- Has thanked: 1597 times
- Been thanked: 769 times
An impressive set of captures Brian!
~ Petrus ~
Flickr
https://www.flickr.com/people/194757663@N08/
LS80THa DSII - Calcium II K module 12mm - Lunt Herschel wedge 1.25" - Quark Chromosphere - Solarscout Quark - Sol'Ex
Flickr
- Has thanked: 17855 times
- Been thanked: 17003 times
Nice work, Brian!
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7327 times
- Been thanked: 8907 times
These are fabulous Brian, I'm glad you got to see these beautiful prominences keep up the good work in the sugar bush
Thanks for all of your positive feedback and support on the images...always appreciated
Kevin and David...
Thanks for your feedback...very much appreciated
David, the image is a composite of separate full disk and limb exposures but not a mosaic of multiple frames. Not as masterful as it may seem, but thanks
