AR3256 & Friends | Cont, CaK, Ha | March 24th 2023
Has thanked: 1188 times
Been thanked: 1382 times
Post by MalVeauX »
Hi all,
Clear skies this morning with a deep blue, wonderful transparency and some sub-arc-second seeing to go with it (around 0.8~1 arc-second peaks this morning). Visual was wonderful, the complex active region group of AR3256, 3257 & 3259 make a lovely area rich in faculae, filaments, fibrils, and fantastic penumbra around their larger spots and it's all facing right at us near the center of the disc. Great mottling in Halpha near most of the areas. I did a quick imaging session to capture the multi-group region in high resolution with the sub-arc seeing.
B&W:
False Color:
And some other areas of interest from the session:
B&W:
False Color:
davidem27
Has thanked: 81 times
Been thanked: 247 times
Re: AR3256 & Friends | Cont, CaK, Ha | March 24th 2023
Post by davidem27 »
I think you did an outstanding effort with amazing results!
What equipment did you use?
I am interested in particular for hydrogen alpha images: you got a flat in band field with also prominence included.
No double rim in the border of the Sun and great uniformity.
My sincere compliments.
White light: Skywatcher 120 ED and Borg 76 ED with Baader Herschel Wedge and filters
H-alpha: Lunt LS50T Ha BF600, 120 ED modified by Lunt etalon. Thousand Oaks 0.9 Å Prominance filter
Calcium II K: Lunt B1200
www.volpetta.com
We are curious. We need equipment, we need seeing, we need time
Has thanked: 17853 times
Been thanked: 16996 times
Post by DeepSolar64 »
WoW, Marty. Very nice. I had really good seeing today too. I find it amazing that you saw the faculae involved with the big active region complex in the south central part of the sun. What scope and filters were you using to view the sun visually? I have also occasionally got faculae well inside the disc. I usually see it as more of a disturbance in the granulation field when doing so and it's usually with the C102 and the wedge and 540nm filter.
Excellent on all but it's the photosphere ones that grab me.
Rusted
Has thanked: 8172 times
Been thanked: 1943 times
Post by Rusted »
Gorgeous results! As always from you! :bow
Has thanked: 20819 times
Been thanked: 10489 times
Lovely, as always Marty!
Has thanked: 8559 times
Been thanked: 8290 times
A great set of images, Marty. Very nice.
Averton
Has thanked: 3303 times
Been thanked: 2312 times
Post by Averton »
As you have said, seeing is everything!!!
Lovely images - any chance of sending some of that sub arc second seeing our way? Thanks :)
Clare & Peter
Post by MalVeauX »
Thanks all, :bow
davidem27 wrote: Fri Mar 24, 2023 10:40 pm What equipment did you use?
I use the following:
Celestron 150mm F8 achromatic doublet
Aries tri-band D-ERF (214mm diameter with masks)
Photosphere: No D-ERF, just used a Baader Ceramic-Cool 2" Wedge with a 540nm Continuum filter and ND3 filter with IMX290 sensor and 1.6x barlow
CaK: Tri-band D-ERF masked to 120mm (F10), Lunt B1200 (12mm) calcium module, IMX290 sensor and 1.6x barlow
H-alpha: Tri-band D-ERF masked to 150mm (F8), Lunt 60 mod (air etalon 1), 10mm blocking filter + ITF, Baader TZ4 4x telecentric, PST etalon (air etalon 2), 0.6x reducer, IMX174 sensor
All my mods are documented here:
viewtopic.php?t=26560
viewtopic.php?t=34331
viewtopic.php?t=36228
DeepSolar64 wrote: Sat Mar 25, 2023 6:01 am I find it amazing that you saw the faculae involved with the big active region complex in the south central part of the sun. What scope and filters were you using to view the sun visually? I have also occasionally got faculae well inside the disc.
As above for equipment but with an eyepiece; in the photosphere its hard to see faculae directly facing us, but they leap out in calcium, one of my favorite parts of calcium is just that. And the mottling of the h-alpha chromosphere network over those faculae match up.
Marty,
Yes, in calcium it would be better. That's why I want one of those Antlia 3nm K-line wedges. While not narrow band enough to see most CaK features in the lower chromosphere, they do better than many other " continuum " filters at seeing faculae on the photosphere well inside the limb. In ultra-narrowband CaK they are called " plages " just like in Ha because one is then seeing more chromosphere than photosphere.
cte
Has thanked: 387 times
Been thanked: 635 times
Post by cte »
All these pictures are incredibly sharp and detailed. I'm impressed by the great contrast reached in H alpha, uncountable tiny details
Ibbo
Has thanked: 2443 times
Been thanked: 1650 times
Post by Ibbo »
Nice set Marty.
KMH
Has thanked: 658 times
Been thanked: 772 times
Post by KMH »
Great collection - really nice details. I'd like some of that seeing, too!
Kevin
Jordan Konisky
Has thanked: 386 times
Been thanked: 270 times
Post by Jordan Konisky »
Well done, Marty. WL images are my favorite.
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
Averton
Post by Averton »
KMH wrote: Sat Mar 25, 2023 6:13 pm Great collection - really nice details. I'd like some of that seeing, too!
Kevin
Hang on Kevin, we asked first :) If there is any left over we'll be sure to send it on!
Clare & Peter
arnedanielsen
Has thanked: 6305 times
Been thanked: 7324 times
Post by arnedanielsen »
Wonderful images Marty!
Arne
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
pedro
Has thanked: 14 times
Been thanked: 6691 times
Post by pedro »
Great images Marty
The LUNT60 mod os working great
