Suffering from this problem.
Taping on a elbow addapter on the the Prom works.
But not on the Chromo. Even pushing a bit of UK plastic milk bottle between the round end of the plug and the etalon body.
I went back and tried my Samsung Tab8 power supply and the plug on that is a good fit and gets to temperature. With the above bodge.
I tried all my power leads and just one other worked, a white one again.
I have ordered a 2m long Samsung Tab8 replacement lead to see if that works.
Looks like the black ones are made down to a price.
Cheers. Andrew.
Quark Plug failure to contact
- Has thanked: 3317 times
- Been thanked: 1907 times
- Has thanked: 20825 times
- Been thanked: 10499 times
Re: Quark Plug failure to contact
Sadly this issue will be the death of many a good Quark with time.
The USB power supply is just a ridiculous design idea in terms of longevity.
- Has thanked: 4379 times
- Been thanked: 3977 times
Repairing the Quark's USB connector is a pain, but not difficult. It only requires hot air and a bit of soldering paste skill. I've already repaired two and it's a half hour job. It is better to replace the micro USB with another connector, even if the aesthetics suffer a little.
Temporary fix. Thin plastic shoved in on the shorter side of the plug between it and the housing.
One works again, fortunately the more used Chromo, with a decent plug from a Samsung Tablet charger. So taped that on.
The Prom works with a cheap elbow connector taped on which makes the contact good.
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 288 times
- Been thanked: 244 times
pupak wrote: ↑Wed Mar 29, 2023 8:29 pm Repairing the Quark's USB connector is a pain, but not difficult. It only requires hot air and a bit of soldering paste skill. I've already repaired two and it's a half hour job. It is better to replace the micro USB with another connector, even if the aesthetics suffer a little.
Do you have any photos of this procedure? Would be good to know how to do it in the event of USB plug failure.
I don't have photos. It's a routine procedure. The Quark must be disassembled, carefully remove the original connector with hot air, and then solder a new one using solder paste. It is better to solder only thin flexible wires and use a different connector. The wires are brought out through the opening of the original connector.
- Has thanked: 2924 times
- Been thanked: 424 times
I purchased a right angle plug and am going to zip tie it to the housing.
Lunt pressure tuned 60mm
Orion ST 80mm
Bausch and Lomb 90mm
Quark Chromosphere / 130mm ERF
Antlia 35mm prism with 1.25" cak filter
Starfield 2" herschel wedge
Celestron 10x42 white light binos
various Barlows and Filters
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
Apollo Mini IMX 429m
Apollo -M Max IMX 432m
Sky Watcher SolarQuest
EQ 5 Black
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
