Clouds broke mid afternoon allowing me to run off a few scans with the 72ED/Hoya ND 16 and Sol'Ex in the Halpha and Helium D3 wavelengths. 16x sidereal speed used on CEM60 to force the scans. Halpha image is a stack of four out of eight,stacked in Autostakkert and minimal processing in Photoshop CS2.
The Helium D3 though is a single image created in INTI using the free line tool,using slight noise reduction in PS CS2,both images have been flipped and rotated to the correct orientation.
Alun
Hydrogen alpha & Helium D3 10th Apr 23
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
SW Evostar 72ED for full disk imaging
Sol'Ex SHG
80mm f/7 achromat used with pressure tune module off the Lunt with Lunt 100mm ERF
Bresser 90 f/10 achromat used for CaK & white light imaging & PST mod with Lunt 100mm ERF
Coronado SM40 (pre Meade) and BF10 filter set + SMII 60 richview DS etalon
Skywatcher EQ6 Pro and Ioptron CEM60
Then there is all the night kit which is far too long a list to write up here!
More images on view on my Flickr page...https://www.flickr.com/photos/alun_h/
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 42 times
- Been thanked: 1487 times
Re: Hydrogen alpha & Helium D3 10th Apr 23
Your H-alpha is really sharp! A little bit of stacking really helps.
I haven't done too much Helium imaging, but I did find it interesting to compare H and He prominence close ups.
- Has thanked: 17672 times
- Been thanked: 8793 times
- Alun_H
Thank you Douglas,Alexandra.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- rsfoto
- Has thanked: 9417 times
- Been thanked: 5583 times
Hi Alun,
Great results. Rain here at my place which is good.
- Has thanked: 1 time
- Been thanked: 2714 times
Beautifull Ha image, and D3 image too, considering the difficulty to get one !
- Alun_H
Thank you Rainer,Christian.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
