my first hbeta with open slit
highfnum
Has thanked: 57 times
Been thanked: 1189 times
Post by highfnum »
here is regular filter Ha to show what I'm trying to lock on
Capture 2022-07-03T12_24_40a66pqrk.jpg (170.61 KiB) Viewed 1534 times
hbeta
HeD3
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: my first hbeta with open slit
Post by p_zetner »
The H beta looks good and it’s great to see the HeD3.
Has thanked: 17648 times
Been thanked: 8787 times
Wow!! that is really great :bow :hamster:
ChrisHalpha2017
Has thanked: 259 times
Been thanked: 237 times
Post by ChrisHalpha2017 »
this is not bad at all :
Could you send me a shematic of your spectroscope ? I think i could look at it and help you to improve it ( if you are interested of course .)
spectro-coronographe ,Bresser 127/1200 ; Bresser 102/1350 , ASI 178MM
highfnum
Post by highfnum »
its classic design
60mm X 700mm scope
50mm X 200mm collimator
1200lpmm grating.
50mm X 300mm imaging scope
and..
slit is reworked surplus shed
ChrisHalpha2017
hmmmm ,
i wouldnt use a 50mm diam 300 mm imaging lens : it means you have a factor k= 1.5x ; that means the final image will be bigger but fainter (less light) . That could explain loss of contrast and loss of sharpness a bit. and it'll limit the range of eyepieces you can use if you want to watch live.
f/D=12 isnt bad :) what camera are you using? have you calculated your sampling rate ? I can do it for you if you give me the camera brand model (i'll will find the pixel size). I wonder if you're not oversampling your prominences image ..
and with some thinking i would even say that a pair of binoculars objectives lens (30 mm diam 135mm f) could be much better : you might gain more light. What size grating do you have ?
highfnum
Post by highfnum »
I can u a shorter 50mmX200MM F4 imaging scope
I thought bigger was better
i use either zwo asi290mm or asi178mm
grating is 1200lpmm 35mmX35mm
