ImPPG version 1.9.1-beta
GreatAttractor
Has thanked: 611 times
Been thanked: 592 times
Post by GreatAttractor »
ImPPG v. 1.9.1-beta is out with the following bug fixes:
  • Invalid channel order when loading 8-bit RGB images
  • Cannot enable adaptive unsharp mask
  • Crash when using adaptive unsharp mask in CPU & bitmaps mode
Homepage: https://greatattractor.github.io/imppg/
Download: https://github.com/GreatAttractor/imppg ... 1.9.1-beta
My software:
My images
Has thanked: 13721 times
Been thanked: 6995 times
Re: ImPPG version 1.9.1-beta
Thanks Filip,
I tried to use it but I can't open it, I get this error, any ideas?
ImPPG 2023-05-14 161819.png (340.06 KiB) Viewed 718 times
Kind regards
GreatAttractor
I've just downloaded it and it ran fine, libcfitsio-3.dll is present in imppg-win64.zip. Can you try downloading again, unpacking to a fresh directory and running from there?
On another note: did you copy "imppg.exe" somewhere else (and renamed it "imppg 1.9.exe"?) It has to stay in the same folder as all the other files (DLLs, images etc.). However, it's fine to make a shortcut (link) to imppg.exe (e.g., on the Desktop).
My software:
My images
