12th May, Mac 8", Ha HR AR & Loop)
- Valtori
- Has thanked: 312 times
- Been thanked: 182 times
Hello Everybody!!
On the 12th of May in 17:00 local time I managed to catch some decent seeing for Ha imaging in High Resolution with my Mac Alter 8".
After the session, already during processing, I discovered a loop. No choice to restart session to pay more attention to loop.
So I present what I managed to get: image with and without a loop for a better picture of the active area.
Aries ERF, Mac Alter 8", Quark Chr., Red.0.5, ASI174, FC, AS!3, AI, PS
Thank you for looking!!
Val
Val
- 12052023 Ha HR AR1.jpg (826.21 KiB) Viewed 1551 times
- 12052023 Ha HR Lmb Mn.jpg (795.32 KiB) Viewed 1551 times
- 12052023 Ha HR Lmb Lp.jpg (750.64 KiB) Viewed 1551 times
- rigel123
- Has thanked: 8659 times
- Been thanked: 8895 times
Re: 12th May, Mac 8", Ha HR AR & Loop)
Gorgeous shots Val! Love that little bit of bright surge in the last image.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
- Has thanked: 4418 times
- Been thanked: 4014 times
This is fantastic set of detailed pictures. Perfect work.
- Valtori
Warren, Ivan and Petr, thank you very much for kind words!!
Val
The time difference between shots 2 & 3 is 10 minutes. So surge appeared during this time.
Val
- arnedanielsen
- Has thanked: 6353 times
- Been thanked: 7411 times
- Been thanked: 5016 times
- Has thanked: 401 times
- Been thanked: 652 times
Excellent imaging with the quark. Do you use a narrow band pass filter after the quark to improve contrast ? I was reading your setup, and you write about red 0.5 before the asi174
- VasilevIvan
- Has thanked: 400 times
- Been thanked: 267 times
Great shoots with nice contrast, Valery!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
What kind of reducer do you use Val ? With mine, a 31.8 diameter 0.5 x reducer, I get a lot of vignetting with the asi 174, when trying to reduce the cone of light from a 5x televue barlow and daystar combo. On the other hand when I use the smaller asi 120 sensor I have no troubles
- Has thanked: 9387 times
- Been thanked: 6199 times
These are excellent, Val. First one is superb, amazing detail, contrast and great processing.
- Has thanked: 18105 times
- Been thanked: 8941 times
