Dear friends,
1 hour 47 minutes timelapse of AR3293, 3296 and 3297 in H-Alpha created from 314 recordings between 13:03 and 14:50UT on May 12th 2023. Each recording was 15 seconds long with a framerate of 100 (1500 frames) and 5 seconds delay between each recording.
The recordings where obtained using a using a 90mm Coronado filter in front of a StellaMira 80mm ED f/10, Baader 35nm H-Alpha, BF15 w/Beloptik ITF, Baader Q-Barlow 1.3x and Player One Mars-M mounted on a ZWO AM5 mount guided with Hinode SolarGuider.
The 200 frames from each recording was stacked in AutoStakkert!3 before they were aligned, sharpened and contrast stretched in ImPPG.
The frames was then cropped, resized to 2/3 and the animation was created in PIPP at 15fps effectively compressing the 1 hour 47 minutes of duration down to just 20 seconds.
Unfortunately I was busy imaging other parts of the Sun and in other wavelengths when the eruption started, but at least I managed to get parts of it.
Click on image to view in full size on AstroBin.
Arne
1 hour 47 minutes timelapse of AR3293, 3296 and 3297 in H-Alpha 12th of May 2023
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- Peterm
- Has thanked: 1733 times
- Been thanked: 1488 times
Re: 1 hour 47 minutes timelapse of AR3293, 3296 and 3297 in H-Alpha 12th of May 2023
This is a fabulous animation Arne, great capture of the flare to the North!
Lunt 80Tha S/S & D/S / B1800; Quark Chromosphere; SkyWatcher 120 Evostar; Celestron SE6; Celestron AVX; Berlebach Planet; ZWO174MM & 432MM & 533MM; Powermate 5X; Lunt Solar Wedge; Hinode SG; Airy Labs SSM
Astrobin: https://www.astrobin.com/users/PeterM/
BOSS team: www.bosssupernova.com
- Has thanked: 4219 times
- Been thanked: 3818 times
Very nice animation. Good work.
- arnedanielsen
Many thanks guys! I'm very happy to hear that you liked it!
Arne
Arne
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
Lovely animation Arne.
- arnedanielsen
Thank you very much!
Arne
Arne
- Has thanked: 20442 times
- Been thanked: 10248 times
Super time lapse Arne!
- arnedanielsen
Thanks Mark!
Arne
Arne
