Do you think this diaphragm for lamps might work for telescopes
diaphragm
- Has thanked: 414 times
- Been thanked: 591 times
- Has thanked: 1 time
- Been thanked: 2713 times
Re: diaphragm
What would be the use of the diaphragm ?
The only time I stop down the aperture of a telescope is for Ca K full-disk imaging. This is for reason of f-ratio and heat load.
This is no need for a diaphragm for this, only a piece of cardboard. On top of that I use white cardboard so it does not warm up when exposed to the Sun.
Re: diaphragm
These thoughts come when you've been locked inside the house under a cloudy and rainy sky for a month... I understood that it's all a game of diameter, f and length. I ordered a herschel apm, and after a 430nm filter and surely I will have to close the aperture of my refractor and I thought a mechanical diaphragm was more practical. I had already noticed the problem of wavelengths / diameter with the continuum filter, not excessively, but if closed from 80 to 70 or 60 it improves a little
Re: diaphragm
In any case the price is reasonnable. Maybe I could use one, one of these days.
Thanks for pointing this !
