this morning the sky is much better, I did some tests, with and without irvcut, if I remove the iruvcut filter the photo is very blurry, this is the result of a "good" shot
80/1000
asi1600mm Pro
Shutter=2.8ms
Gain=132
Sensor temperature=10.0°C
continuum baader 1.25 7nm
uv/ir baader 2"
sun 23/05/2023
- Has thanked: 473 times
- Been thanked: 624 times
- Has thanked: 9313 times
- Been thanked: 6153 times
- Been thanked: 8906 times
Re: sun 23/05/2023
That's a great close up yes, I always use a UV/IR cut filter with everything, it does no harm only good.
- Has thanked: 17849 times
- Been thanked: 16989 times
Re: sun 23/05/2023
That big AR13310 spot is getting a lot of attention!
- Has thanked: 20803 times
- Been thanked: 10478 times
Re: sun 23/05/2023
Good shot!
