Okay, firstly these last 3 months here in NE Scotland have been appalling for imaging, mostly cloudy (but little rain!). Any opportunities are to be treasured - and the only real two occasions have been with poor seeing. (Afternoons have offered slightly more chances, but by then the air is really too turbulent).
I have used a ZWO 174MM-C successfully with a tilter - achieving interference-free imaging first time.
I have recently added an ApolloM-Max to my bag of cams, to use with a 102mm f11 'scope and Daystar Quark-C. UV/IR cut filter and the imaging train is straight-through.
The built-in tilter is set so one of the trio of screws is at zero position, the other two at 2mm.
I'm still getting Newton's Rings quite prominently.
May I ask other users of this camera how they have their own tilt set.
Tilt for Ha
- Has thanked: 2977 times
- Been thanked: 2082 times
Re: Tilt for Ha
Im having it constantly set to 3mm. So quite a lot but then its ok with my equipment.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 896 times
- Been thanked: 314 times
Re: Tilt for Ha
Thanks Dennis, that's 3mm on the two screws?
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
Re: Tilt for Ha
I measured a maximum gap of 3mm between the plates.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Re: Tilt for Ha
Also make sure to have the longer side of the chip as tilt axis, not the shorter one. More effective.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Re: Tilt for Ha
Thanks Dennis - I'll check.
Meanwhile the clouds are stubborn once again!
Call me Geoff.
- Has thanked: 414 times
- Been thanked: 591 times
Re: Tilt for Ha
Thanks - I had no problem with my ASi 174 Cool and the ZWO tilt.
Only with the ApolloM.
Cloud still annoyingly stubborn to check.
Call me Geoff.
- Has thanked: 1 time
- Been thanked: 2713 times
Re: Tilt for Ha
Indeed, the Newton rings are very prominent with this camera. This is the first time I've seen Newton rings with such a contrast.
On mine, I had to introduce a tilt of 1.6 mm. In other words I've a gap of 1.6 mm near one screw, and minimum gap on the two oppositive screws.
It looks OK like this.
