How do you study and observe granulation in H Alpha?
Solarscout
Has thanked: 9 times
Been thanked: 91 times
Post by Solarscout »
Apparently in H alpha granulation shows up more as a mottled surface of dark and bright patches. I tried to observe granular cells in white light but not able to see anything
rigel123
Has thanked: 9373 times
Been thanked: 9590 times
Re: How do you study and observe granulation in H Alpha?
Post by rigel123 »
Granulation is seen in the Photosphere and will not be seen in Ha. You need good seeing along with enough resolution to study the granular cells. The mottled surface you see in Ha are the spicules in the chromosphere.
I suggest you start out with this book as many of the questions you ask can easily be answered in this great little guide:
https://www.amazon.com/Observing-Sun-Po ... 101&sr=8-5
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Solarscout
Thanks. I read this page which said that granulation is visible in H Alpha?
"Granulation - the mottled appearance of the solar disk as seen in Hydrogen Alpha. It will appear as bright patches separated by darker boundaries. Granulation is an illustration of convection in the Sun, the process by which heat flows from the interior to the surface of the Sun. When you are looking at the granules, you are looking at hot blobs of matter that are rising to the surface of the Sun from the even hotter interior, cooling off, then sinking back into the interior again. Since granulation is the process by which heat flows from the center of the Sun to its exterior, it is present even at solar minimum."
Dennis
Has thanked: 3434 times
Been thanked: 2528 times
Post by Dennis »
Solarscout wrote: Mon Aug 14, 2023 5:25 pm Thanks. I read this page which said that granulation is visible in H Alpha?
I was stumbeling over this too some time ago. The part about the granulation is wrong. It is not related to the image shown nor to h-alpha in general.
Also the other images appear to be extremely low in resolution / quality, maybe from early days of h-alpha filters.
Solar granulation is visible with wl-filters (photosphere). The term "h-alpha" i connect with narrow band filters.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Ca-K: homebrew (includes 2x 1.5A filters, thanks Apollo), corrective lenses (thanks again Apollo)
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
rigel123
Post by rigel123 »
Where was this quote? In Jamey's guide on pages 24 - 26 the granulation is clearly described as a Photospheric phenomenon only. The mottled appearance of the chromosphere comes from spicules.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Dennis
Post by Dennis »
rigel123 wrote: Mon Aug 14, 2023 7:26 pm
https://itu.physics.uiowa.edu/labs/obse ... atures-sun
Triband C9.25
Barlows:
-2x TMB 1.8x
rigel123
Post by rigel123 »
Whoever wrote that report must have read something wrong in whatever sources they utilized.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Has thanked: 18637 times
Been thanked: 17784 times
Post by DeepSolar64 »
The granulation seen in the chromosphere are known as " the mottles ". They are basically spicule clusters that cover the chromosphere of the sun like fur on a cat. Visually they appear as a mottling of the chromosphere and are hard to resolve by eye. Imaging however reveals their true nature and they show up really well in inverted images resolving the spicules themselves, especially with larger apertures. The white light photosphere granulation appears as a fine texturing of the photosphere visually and the individual granules that make up the texturing are quite small, 1.5" or smaller. They are difficult visually but show up very well in images through 6" and larger apertures. These granules are the convection cells of the photosphere.
Has thanked: 1 time
Been thanked: 2816 times
Post by christian viladrich »
DeepSolar64 wrote: Tue Aug 15, 2023 4:43 am The granulation seen in the chromosphere are known as " the mottles "
There is no granulation in the chromosphere. As said above, granulation refers to the convection cells visible in the photosphere. The interior of the cell is bright while its frontier is dark.
http://astrosurf.com/viladrich/astro/so ... 0-OIII.jpg
In the lower heights of chromosphere (visible in Ca K or H) , reverse granulation is visible : the interior of the convection cell is dark, while the frontier of the cell is bright.
http://astrosurf.com/viladrich/astro/so ... -014nm.jpg
Higher the the chromosphere (visible in Ha), there is no granulation visible at all. Convection does not reach so high.
