Thanks, i'll buy it and probably go for an Herschel over an astrosolar film. I suppose it would be better.
Choosing herschel
- Has thanked: 5 times
- Been thanked: 16 times
Re: Choosing herschel
I'm near to buy a lacerta herschel wedge with nd3 filter but i wonder if i also need a polarizing filter in addition with a G band ?
I found that for visual use it needs a nd5 filter.
- Has thanked: 18644 times
- Been thanked: 9236 times
You wont need a polariser with the G Band
Nice to know, thanks. It will works like nd3 with continuum or being brighter ?
Finally i tried astrosolar film this week-end and i rather go with an herschel wedge, i feel it more secured.
I found my G band works best with the wedge with ND1.8
I continue to collect informations about G band and i found one that makes me a doubt : seeing in my observation place is average to good, so is it a good choice or must go for a continuum ?
I use a takahashi fc-100 doublet, so i guess it's better corrected in green than blue ?
- Has thanked: 16165 times
- Been thanked: 8216 times
Oops sorry was talking imaging with the g band.
- astroshot
- Has thanked: 199 times
- Been thanked: 129 times
The Baader Cool Ceramic Herschel Wedge is excellent.
Michael.
Michael.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
TEC140
- OlegLviv
- Has thanked: 759 times
- Been thanked: 706 times
With which telescope do you have the best G band result?marktownley wrote: ↑Mon Nov 20, 2023 10:26 pm I found my G band works best with the wedge with ND1.8
https://www.facebook.com/oleg.lavigne/
https://www.astrobin.com/users/RamonLviv/
https://www.astroclub.kiev.ua/forum/ind ... ic=46758.0
Telescope: TS 152/900
Baader D-ERF 160MM
Baader 1.25 GPC
Lunt 50mm
Coronado BF15
Camera: Apollo Max 432M/QHY 290MM
Mounh: Sky Watcher AZEQ6
Telecentric Lense: Televue Powermate 2.5x/4X/5X
Baader D-ERF 160MM
Baader 1.25 GPC
Lunt 50mm
Coronado BF15
Hi Oleg,OlegLviv wrote: ↑Fri Nov 24, 2023 8:43 amWith which telescope do you have the best G band result?marktownley wrote: ↑Mon Nov 20, 2023 10:26 pm I found my G band works best with the wedge with ND1.8152/900 or 127/1200?
I've not tried it with either scope yet to be honest, onluy my 80/600 stopped down to 60/600. I suspect I will use it with the 127/1200 though as I can rarely use 152mm aperture with Ha, so, being able to use it at 430nm will be even less opportunities in a year will be proportionally less. A slower focal ratio scope will always perform better at the shorter wavelengths though.
Yes. Lesser quality refractors will still have some spherical aberation at 430nm, however importantly it also helps with oprtimal sampling when imaging.
