Choosing herschel
EboO
Has thanked: 5 times
Been thanked: 16 times
Re: Choosing herschel
Post by EboO »
Montana wrote: Fri Nov 10, 2023 7:45 am Others have looked visually and enjoyed the view. The faculae stands out more.
Thanks, i'll buy it and probably go for an Herschel over an astrosolar film. I suppose it would be better.
EboO
Post by EboO »
I'm near to buy a lacerta herschel wedge with nd3 filter but i wonder if i also need a polarizing filter in addition with a G band ?
I found that for visual use it needs a nd5 filter.
Has thanked: 18738 times
Been thanked: 9273 times
You wont need a polariser with the G Band
EboO
Post by EboO »
Nice to know, thanks. It will works like nd3 with continuum or being brighter ?
Finally i tried astrosolar film this week-end and i rather go with an herschel wedge, i feel it more secured.
I found my G band works best with the wedge with ND1.8
EboO
Post by EboO »
I continue to collect informations about G band and i found one that makes me a doubt : seeing in my observation place is average to good, so is it a good choice or must go for a continuum ?
I use a takahashi fc-100 doublet, so i guess it's better corrected in green than blue ?
Has thanked: 16236 times
Been thanked: 8253 times
Mark, for visual I think you would need more than ND1.8 :)
Montana wrote: Tue Nov 21, 2023 12:09 pm Mark, for visual I think you would need more than ND1.8 :)
Oops sorry was talking imaging with the g band.
astroshot
Has thanked: 202 times
Been thanked: 129 times
Post by astroshot »
The Baader Cool Ceramic Herschel Wedge is excellent.
Michael.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
EboO
Post by EboO »
It seems to be best choice.
OlegLviv
Has thanked: 763 times
Been thanked: 711 times
Post by OlegLviv »
marktownley wrote: Mon Nov 20, 2023 10:26 pm I found my G band works best with the wedge with ND1.8
With which telescope do you have the best G band result? :bow 152/900 or 127/1200?
https://www.facebook.com/oleg.lavigne/
https://www.astrobin.com/users/RamonLviv/
https://www.astroclub.kiev.ua/forum/ind ... ic=46758.0
Telescope: TS 152/900
Baader D-ERF 160MM
Baader 1.25 GPC
Lunt 50mm
Coronado BF15
Camera: Apollo Max 432M/QHY 290MM
Mounh: Sky Watcher AZEQ6
Telecentric Lense: Televue Powermate 2.5x/4X/5X
OlegLviv wrote: Fri Nov 24, 2023 8:43 am
Hi Oleg,
I've not tried it with either scope yet to be honest, onluy my 80/600 stopped down to 60/600. I suspect I will use it with the 127/1200 though as I can rarely use 152mm aperture with Ha, so, being able to use it at 430nm will be even less opportunities in a year will be proportionally less. A slower focal ratio scope will always perform better at the shorter wavelengths though.
EboO
Post by EboO »
Is the best way for using G band is stopping down the refractor ? To avoid as possible the turbulence effects ?
EboO wrote: Sat Nov 25, 2023 6:17 am Is the best way for using G band is stopping down the refractor ? To avoid as possible the turbulence effects ?
Yes. Lesser quality refractors will still have some spherical aberation at 430nm, however importantly it also helps with oprtimal sampling when imaging.
