The smaller pixel size appeals to me?
If the IMX183 is good for Solar capture is the Pro - Cooled" version recommended?
Thanks!!
Steve
Does AMP Glow of IMX183 affect Solar capture?
- Has thanked: 21695 times
- Been thanked: 11040 times
Re: Does AMP Glow of IMX183 affect Solar capture?
Hi Steve
I have a standard 183 and have never experienced issues with amp glow.
- The Sun?
- Has thanked: 17 times
- Been thanked: 15 times
Thanks Mark. Do you use the 183 for Ha capture? Someone told me a grid pattern develops making Ha capture undesirable.
Steve
Steve
- Has thanked: 65 times
- Been thanked: 4568 times
Hi Steve...
I wouldn't expect amp glow to be an issue with short exposures used in solar work, long exposure deep sky work would be where the cooled camera would be much more desirable.
The grid pattern was reported by some uses for Ha imaging but others have no issue...difficult to make a blanket assessment on it.
- Has thanked: 1998 times
- Been thanked: 1442 times
A cooled camera is not necessary for anything other than deep space longer exposure images.
When it comes to a grid pattern it seems to be very dependent on individual samples of the sensor. A true equipment lottery.
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
I've had no grid pattern issues
- The Sun?
Thanks everyone. Now I have to decide if I will play the ASI183MM lottery.
The IMX533 chip should be a good choice too...available in multiple camera manufacturers lineup. Pixels aren't as small but inlike it.
I almost bought one at NEAF two weeks ago but I need to pay off this springs investment in syrup equipment to keep the divorce lawyers at bay
I also use a 183mm for h-alpha no pattern either, I had a 178mm that would occasionally have a slight pattern. Mine seemed gain and exposure related, however it could have just as easily been sure chance.
Rich
