AR3664 Flaring in High Res HA & Continuum | May 8th 2024
- Has thanked: 1261 times
- Been thanked: 1474 times
Hi all,
AR3664 continues to impress, its grown over night with a lot more interesting pneumbra around the umbras in the complex arrangement making for a very beautiful sunspot region to view in continuum. It's also interesting with crazy brim stone and fire in h-alpha and its currently blowing up lower class flares quite a bit. The x-class flare threat is pretty high on this one, so it may blow its top at any time. It's probably close. It hasn't simmered down in days and its growing, so we're going to likely see some x-class flares from this beast. Maybe a few. Between AR3663 and AR3664, these two spots so far will likely easily have the most x-flares for the entire cycle 25 so far in such a short period. I threw in a quick Calcium disc to test an optic at this wavelength and was pleasantly surprised (AT102ED).
B&W:
False Color:
Equipment:
H-alpha:
Aries Tri-band D-ERF (1) -> 150mm F8 Double -> Baader Red 2" Filter (D-ERF 2) -> Air Spaced Etalon 1 -> Baader TZ4 4x Telecentric -> Air Spaced Etalon 2 - > ITF + 18mm BF -> IMX432 Sensor
Continuum:
150mm F8 Doublet -> Baader 2" Wedge -> ND3.0 -> Continuum5 40nm Filter -> 1.6x Barlow -> IMX290 Sensor
CaK Disc:
AT102ED (102mm F7) masked to 60mm (F12) with Lunt Cak B1200 Module -> IMX253 Sensor
(This was an experiment, at full 102mm aperture it showed some contrast loss so the lens is not great at 393nm full aperture, but when reduced to 60mm the contrast shot up very significantly and so the middle of the glass is well figured to 393nm and the filter performs better at F10 or longer anyways, much better)
Seeing was good; here's some live views from FireCapture, this is what I saw at the eyepiece, no processing here, this is the view at these scales in sub-arc-second seeing peaks.
My snail buddy out in the garden doing solar with me!
B&W:
False Color:
Equipment:
H-alpha:
Continuum:
CaK Disc:
- VasilevIvan
- Has thanked: 457 times
- Been thanked: 327 times
Re: AR3664 Flaring in High Res HA & Continuum | May 8th 2024
Great set of images, Marty! Thank you for sharing!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Has thanked: 528 times
- Been thanked: 348 times
Excellent session, so much to see. Nice pic of the observatory's mascot
Thanks!
Thanks!
Lunt LS50THa, B600, single stack
William Optics Z61, Baader solar film filter
DayStar Quark Chromosphere, w/1.25" ZWO UV/IR filter
William Optics Z81
ZWO ASI178MM
William Optics Z81
ZWO ASI178MM
- Has thanked: 65 times
- Been thanked: 4591 times
Hi Marty...
These images from the 8th are excellent...well done
- Has thanked: 167 times
- Been thanked: 368 times
Great images, Marty!
We’ve had a couple of amazing ARs lately.
I appreciate you posting the capture settings.
- rigel123
- Has thanked: 9181 times
- Been thanked: 9428 times
Just an amazing collection Marty!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 18451 times
- Been thanked: 17609 times
Very nice work Marty. I really love the WL view of AR13664 and AR13668. The flaring of them looks great in the Ha images of them as well.
Did you name that snail " Gary "!??
- Has thanked: 913 times
- Been thanked: 864 times
Lovely images. I like the earth in for scale against the prom - it was huge wasn't it.
Fire and brimstone is an appropriate description for the AR - it's just crackling like a beast. How big would the earth be superimposed against the AR?!
- Has thanked: 9707 times
- Been thanked: 6465 times
Terrific images, Marty. Beautiful work.
- Has thanked: 21782 times
- Been thanked: 11095 times
A lovely set of images here Marty!
- MAURITS
- Has thanked: 2617 times
- Been thanked: 5150 times
- arnedanielsen
- Has thanked: 6834 times
- Been thanked: 7823 times
- AstroBees
- Has thanked: 229 times
- Been thanked: 265 times
Every time I see your name in the post header, I know to be prepared to be blown away yet again.
You didn't disappoint this time either. Fantastic images.
Lunt 80mm Ha double stack
Explore Scientific ED152 CF APO with Baader ASTF Whitelight film & Baader Solar Continuum filter
All piggybacked on a Astro-Physics Mach 1.
- MAURITS
