Firecapture 2.7 and SSSMon plugin
- Rob63
- Has thanked: 792 times
- Been thanked: 899 times
Hi Folks,
has anyone else had issues with FC 2.7 and the SSSMon plugin (v0.92)? I can't get it to connect to my SSM (ERROR: Port not available).
I have tried various ports with no change in result and I have removed all "historical" connections for it in device manager.
The SSM is working and connects to the standalone SSMon app ok
FC 2.7 works ok with the plugin SolarMonitor v-1.6 by Paul De Backer
The plugin also works fine in FC 2.5
Thinking it's a bug in FC 2.7 (or the plugin needs updating for 2.7) but I thought I'd check here first in case I am missing something obvious.
Rob.
screenshot
Rob.
screenshot
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Has thanked: 23748 times
- Been thanked: 12123 times
Re: Firecapture 2.7 and SSSMon plugin
Sorry, can't help. I've not used my SSm for a while now.
- Rob63
Hi Nick,
that only applies to the DIY version of an SSM, I use the AiryLab version which doesn't need the "special firmware". I used it successfully on previous versions of FC. I now just use the Solar Monitor plugin by Paul De Backer which does a similar job.
I had forgotten about this post but I will send Torsten an email to see if he can help as I am not sure if Joachim is still developing his SSM plugin.
Cheers,
Rob.
- Has thanked: 197 times
- Been thanked: 515 times
I’m having the same issue as Rob where I keep getting the “port not available” message.
Any advice?
I’m using the Airylab device with Firecap
Any advice?
- Rob63
Hi David,
I would recommend sending an email to Torsten at firecapture http://www.firecapture.de to report this,
if he gets enough reports it may get fixed or at least identify the cause (which may of course be the plugin).
In the meantime i'd recommend the Solar Monitor plugin by Paul De Backer.
Rob.
I spoke with Torsten in regards to this. and he said it is a known issue with v2.7. He said he contacted Joachim but got no response. The only fix for now is to use v2.6
- Has thanked: 1 time
- Been thanked: 3143 times
I've got the same issue with FC2.7.
I hope Torsten will be able to solve the problem.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Don't think Torsten can solve that. It is a problem with the plugin trying to open the port. There seems to have been a change in Java causing this.
Either Joachim has to solve this or switch to my plugin (should still work) https://github.com/paul-db/SolarMonitor
P.
P.
Great Paul !PDB wrote: ↑Sun Apr 16, 2023 4:43 pm Don't think Torsten can solve that. It is a problem with the plugin trying to open the port. There seems to have been a change in Java causing this.
P.
Could you give some directions on how to install the plugin ? I am afraid I have not found an instruction file.
Thanks !
- PDB
Hi Christian,
There is a pdf file with the complete manual and installation guide.
You'll find it at the releases page: https://github.com/paul-db/SolarMonitor/releases
For windows: download and install Latest r'elease.
After unzipping that file in the firecapture plugin folder, also dowload Plugln1-6-5.zip and overwrite the jar file in the firecapture folder.
(never tested it on W11, so don't know if it will be working on W11)
Salutations,
Salutations,
- Rob63
Thanks for your work on this plugin Paul, I have been using it for the last year and it works very well.PDB wrote: ↑Sun Apr 16, 2023 4:43 pm Don't think Torsten can solve that. It is a problem with the plugin trying to open the port. There seems to have been a change in Java causing this.
P.
- Oh, I get it now!
- Has thanked: 10 times
- Been thanked: 8 times
Dear all,
Slowly resurrecting my solar observation activity after years, I haven't posted here for a long time
I'm currently proceeding to the update of the acquisition software, moving to FC only now that Genika is only minimally maintained and will not allow to use the PlayerOne cameras driver. The main drawback I discovered is the problem discussed in this thread, i.e., the impossibility to use AiryLab's SSM measurements as triggering source for the automated acquisition in FC2.7.
The solution of using
seems unfortunately out of date: the "paul-db" github account and subsequent repo cannot be found anymore (at least I could not find it).
Would someone know where is that plugin now stored (if still available somewhere)?
All the best,
Simon
All the best,
Simon
- BGazing
- Has thanked: 311 times
- Been thanked: 395 times
Seconded, can't find Paul's download and FC2.7 and SSM plugin cannot cooperate...SimonDV wrote: ↑Sat May 18, 2024 11:55 am Dear all,
All the best,
Simon
Lunt 80MT DS, 533
