AR3664 Flaring in High Res HA & Continuum | May 8th 2024
Has thanked: 1264 times
Been thanked: 1483 times
Post by MalVeauX »
Hi all,
AR3664 continues to impress, its grown over night with a lot more interesting pneumbra around the umbras in the complex arrangement making for a very beautiful sunspot region to view in continuum. It's also interesting with crazy brim stone and fire in h-alpha and its currently blowing up lower class flares quite a bit. The x-class flare threat is pretty high on this one, so it may blow its top at any time. It's probably close. It hasn't simmered down in days and its growing, so we're going to likely see some x-class flares from this beast. Maybe a few. Between AR3663 and AR3664, these two spots so far will likely easily have the most x-flares for the entire cycle 25 so far in such a short period. I threw in a quick Calcium disc to test an optic at this wavelength and was pleasantly surprised (AT102ED).
B&W:
False Color:
Equipment:
H-alpha:
Aries Tri-band D-ERF (1) -> 150mm F8 Double -> Baader Red 2" Filter (D-ERF 2) -> Air Spaced Etalon 1 -> Baader TZ4 4x Telecentric -> Air Spaced Etalon 2 - > ITF + 18mm BF -> IMX432 Sensor
Continuum:
150mm F8 Doublet -> Baader 2" Wedge -> ND3.0 -> Continuum5 40nm Filter -> 1.6x Barlow -> IMX290 Sensor
CaK Disc:
AT102ED (102mm F7) masked to 60mm (F12) with Lunt Cak B1200 Module -> IMX253 Sensor
(This was an experiment, at full 102mm aperture it showed some contrast loss so the lens is not great at 393nm full aperture, but when reduced to 60mm the contrast shot up very significantly and so the middle of the glass is well figured to 393nm and the filter performs better at F10 or longer anyways, much better)
Seeing was good; here's some live views from FireCapture, this is what I saw at the eyepiece, no processing here, this is the view at these scales in sub-arc-second seeing peaks.
My snail buddy out in the garden doing solar with me! :lol:
VasilevIvan
Has thanked: 643 times
Been thanked: 470 times
Re: AR3664 Flaring in High Res HA & Continuum | May 8th 2024
Post by VasilevIvan »
Great set of images, Marty! Thank you for sharing!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
Lunt 50 Tha, SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
WMoore
Has thanked: 1016 times
Been thanked: 527 times
Post by WMoore »
Excellent session, so much to see. Nice pic of the observatory's mascot
Thanks!
Wayne
Lunt LS50THa, B600, single stack
William Optics Z61, William Optics Z81, Sky-Watcher Evo100 refractors
Antlia dual band ERF
Antlia Solar Discover CaK
Baader solar film filter
ZWO ASI178MM, ASI174MM
8x32 SunOculars
KMH
Has thanked: 813 times
Been thanked: 1155 times
Post by KMH »
Terrific collection! That AR is quite something.
Kevin
cte
Has thanked: 510 times
Been thanked: 756 times
Post by cte »
Very good imaging. 3664 is impressive, reminds me of Carrington sunspots. Could it generate a similar event ?
Has thanked: 66 times
Been thanked: 5092 times
Post by MapleRidge »
Hi Marty...
These images from the 8th are excellent...well done :bow
Deep Sky Work - ASI294MM Pro+EFW 7x36/ASI294MC/Canon 60D (Ha mod), ONAG
DavidP
Has thanked: 199 times
Been thanked: 534 times
Post by DavidP »
Great images, Marty!
We’ve had a couple of amazing ARs lately.
I appreciate you posting the capture settings.
rigel123
Has thanked: 10728 times
Been thanked: 10703 times
Post by rigel123 »
Just an amazing collection Marty!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Has thanked: 19463 times
Been thanked: 18558 times
Post by DeepSolar64 »
Very nice work Marty. I really love the WL view of AR13664 and AR13668. The flaring of them looks great in the Ha images of them as well.
Did you name that snail " Gary "!??
vineyard
Has thanked: 1197 times
Been thanked: 1159 times
Post by vineyard »
Lovely images. I like the earth in for scale against the prom - it was huge wasn't it.
Fire and brimstone is an appropriate description for the AR - it's just crackling like a beast. How big would the earth be superimposed against the AR?!
Has thanked: 10720 times
Been thanked: 7167 times
Post by ffellah »
Terrific images, Marty. Beautiful work.
Has thanked: 23839 times
Been thanked: 12169 times
A lovely set of images here Marty!
MAURITS
Has thanked: 2912 times
Been thanked: 5470 times
Post by MAURITS »
Excellent images Marty.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
arnedanielsen
Has thanked: 7808 times
Been thanked: 9288 times
Post by arnedanielsen »
Lovely results Marty!
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
AstroBees
Has thanked: 275 times
Been thanked: 329 times
Post by AstroBees »
Every time I see your name in the post header, I know to be prepared to be blown away yet again.
You didn't disappoint this time either. Fantastic images.
Lunt 80mm Ha double stack
Explore Scientific ED152 CF APO with Baader ASTF Whitelight film & Baader Solar Continuum filter
All piggybacked on a Astro-Physics Mach 1.
MAURITS
Post by MAURITS »
Great session Marty.
Maurits
