27 May 2024 - Gband - w aperture stepdown
vineyard
Has thanked: 947 times
Been thanked: 911 times
Post by vineyard »
Based on advice from Mark, and seeing there was a short stint of sunshine this morning, I quickly tried 3 different apertures - the native 102mm of the ST102 (so f5), and then 80mm (equiv f6.3), and then 60mm (equiv f8.3). Exact same number of exposures, same % stacked, same ImPPG curve, same GIMP curves. There will be some seeing difference but it wasn't that variable over the 3-4 minutes. The aperture step down makes such a difference - thanks Mark!
I think the 60mm is sharpest at Gband, but the 80mm doesn't seem that far away from it?
102mm
80mm
60mm
ROI at bin1
Same ROI at bin2 w a 2.5x powermate - I actually should have stuck to bin1 as per Marty's spreadsheet
I tried the aperture step down for 540nm continuum as well. Not as much of a difference as in Gband, although the 80mm is still better than the 102mm?
102mm
80mm
60mm
Has thanked: 22096 times
Been thanked: 11252 times
Re: 27 May 2024 - Gband - w aperture stepdown
Great comparison Vin! Less is more ;)
Has thanked: 18669 times
Been thanked: 17811 times
Post by DeepSolar64 »
Vinyard,
I have certainly benefited by stopping my AT72EDII down from 72mm to 40mm while imaging at 430nm and 393.3nm. Mark's advice has proven spot on.
ChrisHalpha2017
Has thanked: 348 times
Been thanked: 285 times
Post by ChrisHalpha2017 »
very nice series ^^
spectro-coronographe ,Bresser 127/1200 ; Bresser 102/1350 , ASI 178MM
Has thanked: 9898 times
Been thanked: 6600 times
Post by ffellah »
Great set of images, Vin.
rigel123
Has thanked: 9431 times
Been thanked: 9629 times
Post by rigel123 »
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
MAURITS
Has thanked: 2651 times
Been thanked: 5186 times
Post by MAURITS »
Nice session Vin.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
vineyard
Post by vineyard »
Thanks all, that's v kind.
Has thanked: 1 time
Been thanked: 2816 times
Post by christian viladrich »
Well done !
The 60 mm aperture is clearly the winner in G-band.
arnedanielsen
Has thanked: 6990 times
Been thanked: 8058 times
Post by arnedanielsen »
Very nice, Vin!
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
vineyard
Post by vineyard »
Thanks both Christian & Arne. Been having a learning curve today in v windy conditions in SW Portugal...ooph.
