21 May 2024 - Ca K and 393-3 nm images
Has thanked: 1 time
Been thanked: 2816 times
Post by christian viladrich »
Weather has not particulary good down here ...
Here are some images taken on May, 21st during a short clearing.
FD image taken with the Altair 393-3 nm :
http://astrosurf.com/viladrich/astro/so ... 93-3nm.jpg
FD with the Alluxa Ca K 0.14 nm (stacked with an Edmund Optics 393-3 nm). Some proms are visible here and there :
http://astrosurf.com/viladrich/astro/so ... -014nm.jpg
Then I pushed the focal length while keeping the IMX533, just to test this configuration. Not surprisingly, the optical quality is not so good on the outside of the view of view. The Airylab telecentric is not designed for such a "large" sensor. The workable field of view seems to be in the range of 2000 x 2000 pixels, which is fine for large sunpot groups. The IMX 533 is doing pretty good even when only 60 frames are stacked.
These are double-stack images (0.14 nm + 0.14 nm). The filter tilt is tuned with the Sol'Ex spectro. Tuning of the second Ca K filter is rather touchy, even with the RAFcamera tilt mount.
I've found out that "tuning by eye" is OK as long as only one Ca K filter needs to be tuned. But when two filters are to be tuned (= tilted), tuning with the spectro is definetly more accurate.
http://astrosurf.com/viladrich/astro/so ... CaK-DS.jpg
Clear skies !
Christian
Has thanked: 9875 times
Been thanked: 6587 times
Re: 21 May 2024 - Ca K and 393-3 nm images
Post by ffellah »
Magnificent images, Christian. Is this with the Saturn M camera ?
LeoD
Has thanked: 1341 times
Been thanked: 1097 times
Post by LeoD »
Stunningly detailed, clear and crispy, to be accompanied by a glass of champagne zero dosage!
What fps did you use for 533 camera?
Leo
vineyard
Has thanked: 947 times
Been thanked: 910 times
Post by vineyard »
That CaK altair filter looks intriguing. As for the detail in the double-stack ones, yowsa!
Dennis
Has thanked: 3435 times
Been thanked: 2529 times
Post by Dennis »
Beautiful images Christian. I wonder if the Baader TZ3 / TZ3s produces a large enough corrected image circle.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Ca-K: homebrew (includes 2x 1.5A filters, thanks Apollo), corrective lenses (thanks again Apollo)
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
rigel123
Has thanked: 9408 times
Been thanked: 9614 times
Post by rigel123 »
Stunning images Christian!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Has thanked: 1 time
Thanks guys !
Dennis wrote: Wed May 29, 2024 1:40 pm Beautiful images Christian. I wonder if the Baader TZ3 / TZ3s produces a large enough corrected image circle.
I have no idea. The Airylab is a divergent doublet associated with a convergent singlet. Unfortunatly, I can't simulate the TOA 150 + Telecentric in OLSO because I am limited to 10 air-surfaces.
Not sure whether the TZ3 has three or four lenses ?
LeoD wrote: Wed May 29, 2024 12:26 pm What fps did you use for 533 camera?
fps for the FD images is about 40 fps (8-bit acquisition). For close-ups, it goes up to about 100 fps when the image is cropped to about 2000 x 2000 pixels. But I have not checked the exact figures.
ffellah wrote: Wed May 29, 2024 10:18 am Magnificent images, Christian. Is this with the Saturn M camera ?
Yes it is, Player One Saturn M SQR with the IMX533 sensor. It is much faster than the equivalent ZWO model.
KMH
Has thanked: 713 times
Been thanked: 914 times
Post by KMH »
Beautiful images and processing! I really like the "look" provided by double-stacked Ca.
Kevin
Valtori
Has thanked: 363 times
Been thanked: 227 times
Post by Valtori »
Incredible CaK DS images, Christian!!
Val
Has thanked: 18653 times
Been thanked: 17798 times
Post by DeepSolar64 »
Awesome work Christian. Absolutely stunning!!
James 😊👍🏼👍🏼
Has thanked: 8897 times
Been thanked: 8676 times
Superb, Christian.
Dennis
Post by Dennis »
They dont state how many lenses are used, but i always thought a telecentric is made from 4 lenses. Even if we knew i doubt they would share the design for simulations.
Triband C9.25
Barlows:
-2x TMB 1.8x
arnedanielsen
Has thanked: 6987 times
Been thanked: 8043 times
Post by arnedanielsen »
Impressive results as always, Christian! Thanks for sharing!
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
Has thanked: 22072 times
Been thanked: 11239 times
Stunning pictures Christian!
When double stacking I have found the filter closest to the objective is the filter that has natively the least amount of tilt to get it on band, is the one that I have to tune each time to get on band. The secondary filter (closest to the camera) is tilted to throw the reflection / ghost off the image.
