Has anyone used this IDS camera?
donboy
Oh, I get it now!
Oh, I get it now!
Post by donboy » Mon Jul 07, 2014 6:39 pm
I read that e2v CMOS cameras aren't plagued with Newton Rings for narrow band imaging. So I investigated and came up with IDS cameras and they have a model that looks interesting: UI-5240CP-NIR-GL. It is a NIR (near infra-red) 1/1.8", 1280x1040 at 50fps, GigE ,cmount equiped with a 70% QE in the 656nm range.
http://en.ids-imaging.com/store/produkt ... 240cp.html
Just wondering if anyone has had experience with this German made camera?
Don
Bortle 6.5
AT RC8 CF, Celestron C8, WO 66mm SD Zenithstar, Celestron C80ED, Celestron 102GT, ES 127 FCD100 CF
CEM60, CEM25, AZ Mount Pro
ASI294MC Pro, ASI071MC Pro, ASI1600MM-Cool, Atik 414EXC, QHY5L-IIm, ASI224, ASI290mm, Canon T3i modified
Lunt Herschel Wedge, DayStar Quark
Broadcasting live on www.nightskiesnetwork.com
NSN Channel: HeavensDeclareGod'sGlory
My Solar Album: https://www.flickr.com/photos/23705399@ ... 5393470230
My Astro Albums: https://www.flickr.com/photos/23705399@N04
sullij1
Re: Has anyone used this IDS camera?
Post by sullij1 » Tue Jul 08, 2014 1:48 am
Looks like a NO to me. ;)
Look Up!
Post by swisswalter » Tue Jul 08, 2014 4:57 am
Hi Don
thanks for the link. Never hard of it. Do we know something about the Price ?
donboy
Oh, I get it now!
Oh, I get it now!
Post by donboy » Tue Jul 08, 2014 5:18 am
Walter,
I saw a mono version not NIR version 5240 listed by a Swedish firm for sale at 400 euros.
http://www.parameter.se/files/Demo%20st ... 202013.pdf
Don
Bortle 6.5
Post by swisswalter » Tue Jul 08, 2014 5:20 am
Hi Don
that is a good price. So we have to find out with what programm the CMOS cooperates
donboy
Oh, I get it now!
Oh, I get it now!
Post by donboy » Wed Jul 09, 2014 5:21 pm
Walter,
Point Grey has some similar cameras in the Flea 3 USB3.0 : FL3-U3-13E4M-C ($695) and FL3-U3-20E4M-C (not released)
http://www.ptgrey.com/products/flea3_us ... 3_USB3.pdf
Don
Bortle 6.5
jp-brahic
Post by jp-brahic » Wed Jul 09, 2014 5:34 pm
Hello
I tested a few months ago the IDS 3240, an excellent camera with an excellent electronics, but I did not keep it because of impossible to remove the newton ring even with tilt!!! It is the porthole of protection that it make problem
JP
TN 450mm F/D 4 Zerodur
donboy
Oh, I get it now!
Oh, I get it now!
Post by donboy » Wed Jul 09, 2014 9:38 pm
Thanks for the report JP.
Just browsing the Point Grey catalog and came across their BlackFly version of the 1280x960 e2v mono camera for $395
http://www.ptgreystore.com/blackfly-13- ... e-ev76c560
I wonder if the less expensive cameras have poorer coatings on the protective glass chip covers that cause these Newton Rings.
Don
Bortle 6.5
donatpointgrey
Oh, I get it now!
Oh, I get it now!
Post by donatpointgrey » Fri Jul 11, 2014 5:08 pm
donboy wrote:Thanks for the report JP.
Hi Don,
In my experience (which is limited to discussing the problem with customers, I have no hands on experience at all with Newton Rings) we've come to the conclusion that the major source of NR is the sensor cover glass, not the camera optical window (see below). Since camera manufacturers use the same sensors, if the cover glass is the issue, then the NR are out of the camera manufacturers control and for the same sensor, any camera vendors' model could/should have the same issues. This is not definitively proven, but I am always concerned when anyone says "Manufacturer X cameras don't get NR as much as Manufacturer Y" because all the info I've heard about this is annecdotal and a small sample size of cameras (usually 1).
(I guess the one thing that is in the manufacturer's control is the accuracy at which the flange of the camera is parallel to the sensor - however, from what I understand, better placement in this respect may actually make NR worse! Maybe NR is a sign of quality construction? :))
I guess what I'm saying is that if you want an e2v camera - you can buy it from us, or from someone else, and my prediction is that there is no way to see if you'll have NR problems until you get the camera, and your odds of a good one are equal across vendors. (However, I am always interested to hear evidence against this - this is just the conclusion I've come to so far).
For Point Grey cameras, the optical path components, which are really just the sensor and the optical window, are identical quality across models. The sensor is obviously the same, and the optical window is a very low cost component compared to the rest of the camera. The differences are really due to the electronic components. The more expensive cameras will sometimes have the potential to run faster, and also to have more on-camera processing and more I/O capabilities (strobe and trigger signals, etc).
BTW, to clarify what I mean by optical window, the optical path on our cameras goes
- optical window
- about 0.5mm to 1cm space (depending on model)
- sensor cover glass (attached to sensor)
- 0.1mm or so air space
- sensor
The optical window is there to hold dust off the sensor so it will be less visible in the image.
I hope this helps.
Don (the Point Grey Don).
Don Murray
www.ptgrey.com
