ImPPG - Image Post-Processor
Moderator: marktownley
GreatAttractor
Post by GreatAttractor » Sat Feb 21, 2015 10:28 pm
ImPPG performs Lucy-Richardson deconvolution, unsharp masking, brightness normalization and tone curve adjustment. It can also apply previously specified processing settings to multiple images. This time everything is wrapped in a full-fledged GUI, whose operation should be familiar to most amateur astrophotographers.
Some of the interface features:
- freely adjustable processing area (selection) within the image
- non-blocking operation; if you change the selection, previously started processing (if any) aborts and begins for the new selection
- for moderately small selections the application of Lucy-Richardson deconvolution is almost instanteneous, which allows for convenient fine-tuning of the "Sigma" parameter
- tone curve editor with helper functions (invert points horizontally to create a negative; stretch the curve to cover the histogram only)
Screnshots:
The "Prevent ringing" function is highly experimental and may not help in all cases. It aims to reduce ringing around overexposed areas (e.g. a solar disc in a prominence image); it does work quite well in the case I devised it for:
no deringing:
deringing enabled:
but your mileage may vary.
For now only BMP and uncompressed TIFFs (8- and 16-bit) are supported, but I'll add support for more formats (including FITS) soon. The program can be built on any platform which has a C++ compiler supporting Boost and wxWidgets libraries, including Linux (which I use on my laptop) and OS X. As usual, additional details can be found in the README file.
ImPPG is free & open-source, licensed under GNU GPL v3 (or later). Source code and Windows version (32- and 64-bit) can be downloaded from:
http://stargazerslounge.com/blog/1400/e ... processor/
All the material shown in http://solarchat.natca.net/viewtopic.php?f=4&t=14937 has been processed by ImPPG.
My software:
My images
grimble_cornet
Re: ImPPG - Image Post-Processor
Post by grimble_cornet » Sat Feb 21, 2015 10:40 pm
Looks like a great front-end to what was already a very impressive bit of software :bow2
Mike Garbett
Post by swisswalter » Sun Feb 22, 2015 4:06 pm
Hi Filip
thank you so much. I'll have a go with it for sure
Post by marktownley » Sun Feb 22, 2015 4:28 pm
an excellent resource, i shall have to give it a try! :)
Post by swisswalter » Sun Feb 22, 2015 5:00 pm
Hi Filip
it works (tested it on a SAFIX test shot from friday) , but I do not understand it yet :oops:
GreatAttractor
Post by GreatAttractor » Sun Feb 22, 2015 5:46 pm
Walter, all there's really to do is play with the sliders ;)
Of course, if anything is unclear, please post your questions here.
My software:
My images
robert
Post by robert » Sun Feb 22, 2015 6:37 pm
Thanks! I have downloaded it and will have a try
Robert
2018 images https://www.flickr.com/photos/69734017@ ... 1234171714
michael.h.f.wilkinson
Post by michael.h.f.wilkinson » Mon Feb 23, 2015 7:25 pm
I have been a great fan of ImPP for my mosaics, so I will give this further development a try as soon as I can.
GreatAttractor
Post by GreatAttractor » Tue Feb 24, 2015 11:09 pm
New version: 0.1.1
Bug fixes:
– Blank output files after batch processing when L-R iterations count is 0
Download from: http://stargazerslounge.com/blog/1400/e ... processor/
My software:
My images
Post by swisswalter » Wed Feb 25, 2015 5:45 am
Thank you Filip
