Have you managed to test your new Solar scintillation monitor yet on the Sun ?
Magnus
Only very briefly and things seem to be woking - although I am not sure about accuracy yet. I also marked up the breadboard photo in the initial paper to reproduce that layout. Attaching in case it's helpful to others. The Arduino code needed some alteration to work with the Uno as well.
SSM_BreadboardLayout_Small - Copy.jpg (436.79 KiB) Viewed 1735 times
