Solar wind sparks geomagnetic storms
Post by Carbon60 » Tue Mar 28, 2017 5:37 am
A large coronal hole facing Earth is spewing high speed, southerly polarised solar wind, sparking aurora and moving magnetometer needles around the globe.
20170327_Coronal Hole.jpg (109.33 KiB) Viewed 1526 times
The southerly magnetic orientation within the plasma is making this particularly potent, allowing strong magnetic connection with Earth's magnetic field, generating a strong geomagnetic response.
Thanks for looking.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
carlosjackal
Oh, I get it now!
Oh, I get it now!
Re: Solar wind sparks geomagnetic storms
Post by carlosjackal » Tue Mar 28, 2017 8:38 am
Good stuff Stu! This was my first chance to test the temperature controlled version. Here's a raw data shot they look very agreeable.
Carl
Post by marktownley » Tue Mar 28, 2017 8:59 pm
Good data there gents!
Post by Carbon60 » Wed Mar 29, 2017 5:50 am
Thanks, Mark.
Carl, it looks like you're in business! Do you require the excel spreadsheet I've developed to scale and plot the data? Please send me a PM if you do.
Good work.
NEQ6 Pro-mount
carlosjackal
Oh, I get it now!
Oh, I get it now!
Post by carlosjackal » Wed Mar 29, 2017 8:27 am
Thanks Mark!
Stu yes the temperature control is a huge difference. The Eco is keeping to within 0.1 deg and working great!
I got the spreadsheets through PM last time so have them but i didn't get the instructions. The setup guide would be great. Just a note for some reason i cant reply on the PM system.
Thanks again.
Carl
Post by Montana » Wed Mar 29, 2017 11:28 am
Great data and they look very comparable too :hamster: :bow
I got red alerts the other night, it was cloudy and I thought of you, at least you don't require clear skies :)
Post by Carbon60 » Thu Mar 30, 2017 5:43 am
Absolutely, Alexandra.....Clouds are no problem :)
Carl, I'll aim to send you some instructions, but basically copy and paste your CSV data from your captured Spectrum Lab files into column 'A' and then ensure that the charts are set to plot from the start and end of the columns of calculated output data.
Regards
Stuart
NEQ6 Pro-mount
carlosjackal
Oh, I get it now!
Oh, I get it now!
Post by carlosjackal » Thu Mar 30, 2017 10:23 pm
Thanks Alexandra looks to be working well.
That would be great Stuff just need to know how to capture the CSV data as i just have it running live as such.
Cheers Carl
Post by Carbon60 » Sat Apr 01, 2017 6:38 am
Hi Carl,
Setting up sampling rate:
The first task is to set (or check) the sampling rate.
Under SpectrumLab OPTIONS select 'spectrum display settings' and then under the 'spectrum (1) tab ensure that the sampling rate is set to 150 seconds. This provides sufficient resolution for daily data capture.
Setting sampling rate.jpg (214.07 KiB) Viewed 1462 times
Setting up data capture:
Back on the main screen, select FILE and tick 'Export Calculated Data (Continuously)'.
Under the File Contents tab ensure that the column separator value is set to '9' and that the number of columns is set to '2'
Set the column titles as shown (time and frequency) and set the values and format as shown.
Setting exported data format.png (47.13 KiB) Viewed 1462 times
Under the file activation tab set the destination folder to which the data will be saved and tick 'active'. Data will then be captured at the rate set above (150 seconds) and saved in the designated folder.
CSV data:
Your captured data should open as a CSV text file, similar in format to this.....
CSV file.jpg (117.11 KiB) Viewed 1462 times
You can then simply highlight the values (not the headings), copy and paste into cell 'A8' of the Excel spread sheet. The entire column should then automatically populate with the data and the spreadsheet will generate the output data. Don't forget to set cells F3 and F4 with the 'null' frequency (the frequency at which the output from the detector drops to zero) and the 'set frequency' (the frequency set on the detector LCD screen to give an output pitch of 3-4 kHz). Keep cell H4 (filter) set at 8 for now. This can be changed to higher or lower values to modify the output depending on the quality of the input (i.e. noise spikes). Higher numbers here have less of a filtering effect on the data.
Cells K3 and K4 allow you to scale the charts according to your closest 'INTERMAGNET' station if you want to. Simply go online to http://www.intermagnet.org/data-donnee/dataplot-eng.php, select a station closest to your location and plot the relevant data. Take note of the max and min nT values and use these to set cells K4 and K3 accordingly.
The following screen shots just tell you about setting up the charts, which you might already be familiar with.
I hope this helps.
NEQ6 Pro-mount
carlosjackal
Oh, I get it now!
Oh, I get it now!
Post by carlosjackal » Sat Apr 01, 2017 11:24 am
That is fantastic Stu! Thanks for taking the time to do it. I well have a go at this later today.
Cheers Carl
highfnum
Post by highfnum » Sat Apr 01, 2017 1:35 pm
I got some data also from out here in the west
Post by Carbon60 » Sun Apr 02, 2017 5:19 am
Good luck, Carl. I'm sure it will work out.
Looking forward to seeing your data from out west, John.
NEQ6 Pro-mount
