Autostakkert 3
This forum replaces http://www.solarscopereviews.com so that more people can post their own reviews. Feel free to post your review of solar astronomy equipment here! We want as many impartial reviews as possible to help people decide what to buy.
Has thanked: 689 times
Been thanked: 257 times
Autostakkert 3
Post by marktownley » Tue Mar 28, 2017 8:46 pm
The new beta version came out for this earlier this month. It's nice, I like it, some nice feature updates. I did a quick blurb on my website, with links to download.
https://brierleyhillsolar.blogspot.co.u ... eased.html
Has thanked: 555 times
Been thanked: 183 times
Re: Autostakkert 3
Post by Montana » Wed Mar 29, 2017 11:22 am
Thanks for the info Mark, these sound like good features!
PDB
Been thanked: 13 times
Re: Autostakkert 3
Post by PDB » Wed Mar 29, 2017 6:02 pm
Thanks Mark.
Downloaded it today and will start using it from now. (Did a first run without problems, so Beta looks stable)
Re: Autostakkert 3
Post by Montana » Sat Apr 01, 2017 11:03 am
Mmmm it works but impossible to close down. I have to use Ctrl+Alt+del :(
Can't even delete the software, it won't let me. On there for good now unfortunately :(
PDB
Re: Autostakkert 3
Post by PDB » Sat Apr 01, 2017 11:24 am
Hmm, works without problems for me (seems faster that previous version)
Have you tried to "End" it with Task Manager instead of using Ctrl-Alt-Delete.
If you rebooted, you should be able to delete the folder where you unzipped the software. So what error message do you get when trying to delete?
Rgrds,
Re: Autostakkert 3
Post by Montana » Sat Apr 01, 2017 5:17 pm
Problem solved by the very kind Emil :)
I have set it to permanently run as administrator and it now closes fine :hamster:
Has thanked: 181 times
Been thanked: 175 times
Re: Autostakkert 3
Post by Carbon60 » Sun Apr 02, 2017 5:47 am
Thanks for pointing this out, Mark.
I'm not changing a thing on my laptop until after the eclipse...... :)
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
PDB
Re: Autostakkert 3
Post by PDB » Sun Apr 02, 2017 7:28 am
Stu,
then you will need to disable network access to prevent Microsoft messing up your PC with their updates. Wouldn't be suprised if they send out updates in August.
Re: Autostakkert 3
Post by marktownley » Sun Apr 02, 2017 8:40 am
I just need some sunny skies to test it a bit more :D maybe today...
PDB
Re: Autostakkert 3
Post by PDB » Wed Jun 21, 2017 6:27 pm
Has someone tried to process multiple files? Don't get it working with AS!3. I normally use that for stacking an animation series with the same processing settings. It works in AS!2, but not output in AS!3. Maybe I have some setting that conflicts with stacking multiple files.
Re: Autostakkert 3
Post by marktownley » Thu Jun 22, 2017 5:44 am
I've had no probs stacking multiple files. What issues are you getting?
PDB
Re: Autostakkert 3
Post by PDB » Thu Jun 22, 2017 6:23 am
I do analyze, set the % of frames I like, set the alignment points and then press stack. Seems to analyze all the files again, but then stops. No files stacked. I have no problems doing this in AS!2. I have set double stack referenece, maybe that is the problem. (Will give that i try, but just removed my last session ...)
Rgrds,
Re: Autostakkert 3
Post by marktownley » Thu Jun 22, 2017 5:46 pm
How many frames you recording in the avi?
PDB
Re: Autostakkert 3
Post by PDB » Thu Jun 22, 2017 6:09 pm
Not that much. It were around 35 10 second SER files of proms. Taken with the ASI120MM-S so these were not that big. Just tested again. Copied a 1000 frame SER file 10 times. Tried different changes in the settings (double stack, buffering, laplace) nothing helped. You see Step 1 & 2 for each image, but the other steps (allig stack ...) are not done, so nothing saved. Did exactly the same with AS2 (also the 64bit version) no problem. Think I will send an e-mail to Emiel.
Rgrds,
PDB
Re: Autostakkert 3
Post by PDB » Fri Jun 23, 2017 9:45 am
Problem solved. Emil suggested to try automatic selection of alignment points, that did the trick.
P.
Re: Autostakkert 3
Post by marktownley » Fri Jun 23, 2017 9:27 pm
Kool and the gang...
Re: Autostakkert 3
Post by Carbon60 » Wed Sep 20, 2017 5:28 am
Post eclipse..... now downloaded and appears to be running fine :)
Thanks for the heads-up, Mark.
NEQ6 Pro-mount
Re: Autostakkert 3
Post by marktownley » Fri Oct 27, 2017 4:05 pm
I would urge you if haven't done so already to download the latest version of 'v3' as there have been a few bug fixes and certainly for me on my old coal powered laptop things have sped up quite a bit.
http://www.astrokraai.nl/software/latest.php
