Solar Analemma. This outstanding image from Alexandra Hart taken over a period of 4 years charts the midday position of the sun in the sky throughout the year. The north–south component of the analemma results from the change in the Sun's declination due to the tilt of Earth's axis of rotation. The east–west component results from the nonuniform rate of change of the Sun's right ascension, governed by combined effects of Earth's axial tilt and orbital eccentricity.
Merry Christmas, Happy New Year and looking forward to a great solar cycle 25!
Omega 656.3 H Alpha 0.15nm filter as a DS eyepiece filter.
soulvagabond
Oh, I get it now!
Oh, I get it now!
Post by soulvagabond » Sat Jul 08, 2017 6:10 am
Hello everyone.
Since I have read the post https://www.cloudynights.com/topic/5823 ... ?p=7966901, I'm really tempted with the idea of trying it out on my Lunt 50. Sadly, the poster did neither uploaded any photo proof, nor answered my private message to him.
My main question is, which of 2 similar filters, would be a better choice, in my case:
Normal Incidence (doesn't require any tilt, to be on band): http://www.ebay.com/itm/Optical-Interfe ... 9#shpCntId
DP mounted (requires 1-3 degrees tilt): http://www.ebay.com/itm/Optical-Interfe ... 488f8ae32a
Another question, would mounting it right behind the Lunt50 ethalon (which is also around 25mm) could be a better solution?
Thanks!
