Can I double stack Quark + Lunt LS50THa?
teldar_paper
Post by teldar_paper » Sun Sep 03, 2017 11:14 pm
I have the Lunt LS50THa with B400, I thought I could solve 3 problems:
1. See more disk detail
2. Have a bigger blocking filter for imaging
3. Let me use more comfortable, longer focal length eyepieces (right now I have to use uncomfortable 4mm Plossls for high mag)
by getting a Quark Chromosphere as a double stack unit.
From what I'm read online, I just have to replace the B400 with a regular diagonal & put the Quark in it... anything wrong this plan?
_Zakalwe
Re: Can I double stack Quark + Lunt LS50THa?
Post by _Zakalwe » Fri Sep 08, 2017 10:52 am
It will be extremely dim for a start. I tried once with a Lunt 60 and it didn't work.
Post by marktownley » Sun Sep 10, 2017 9:04 pm
Try it and see what happens
teldar_paper
Post by teldar_paper » Tue Sep 12, 2017 7:48 pm
I had to fiddle with a few extension tubes/diagonals to get it to focus, but looking through it at 100x magnification was awesome! I can't imagine that the "native" front-mounted DS etalon could be much better than this. I'll still have to get the feathertouch/moonlite focuser to better handle the added weight of the Quark.
daslolo
Post by daslolo » Thu Feb 20, 2020 9:06 am
extensionS and diagonalS
does it look like this in the end?
LX65 8" ACF
Astrograph
Post by Astrograph » Thu Feb 20, 2020 11:25 am
You can make it work sometimes and sometimes not. It depends on how lucky you are with the two filters being compatible with each other. I did once combine a Quark and a Quantum to see what it was like. The contrast in the bit of the sun I could see was amazing but it was not a practical solution. Its actually a negative for imaging. You will find a very small field that is well corrected but because the image is so dim, exposure time has to be quite long and ultimately causes blur when you stack frames.
Post by Valery » Sat Feb 22, 2020 11:26 am
All depends of both etalons transmission % and blocking filter transmission. The brighter the images in your LS50THa and Quark 0 the better.
I got both LS50THa PT and Quark. DS works extremely well.
Marcus444
Post by Marcus444 » Sat Feb 22, 2020 2:26 pm
I’ve tried using a Quark with both Lunt LS50 and LS60 and had no joy whatsoever. Far too dim and murky, yet I get bright and excellent results with standard double stack filters and binoviewer. As mentioned, must just be down to incompatibility.
Lunt LS60THa, 60FHa
Quark Chromosphere
Baader Herschel wedge
Tak FC-100, TV85
